Find value of a variable by changing value of another (solve (2) perhaps?) - Messages
I'm trying to make a SMath worksheet for calculating flow over weir. The problem is iterative, i.e. when you calculate it "by hand" you have to estimate some values and then check if your estimation is close enough.
Here is my workbook:
suppressed_weir.sm (79.98 KiB) downloaded 1225 time(s).
suppressed_weir.pdf (365.79 KiB) downloaded 823 time(s).
I tried to solve this problem by using "solve (2)" function, but I'm obviously doing something wrong...
Could anyone help me with this?
Cheers,
Sandro
WroteI'm trying to make a SMath worksheet for calculating flow over weir. The problem is iterative, i.e. when you calculate it "by hand" you have to estimate some values and then check if your estimation is close enough.
The masflow rate of a weir is not iterative.
https://www.brighthubengineering.com/hydraulics-civil-engineering/65880-open-channel-flow-measurement-5-the-rectangular-weir/
WroteHi,
Cheers,
Sandro
Hope this is enough for you.
Solve can't work with units.
Sometimes it just refuses even without units.
Use roots(), FindRoot(), al_nleqsolve() if it fails.
In this order generally.
Regards.
suppressed_weir1.sm (82.41 KiB) downloaded 1225 time(s).
WroteHope this is enough for you.
Use roots, FindRoot, al_nleqsolve if it fails.
Regards.
Thank you, overlord, that works exactly as I wanted!
WroteThe masflow rate of a weir is not iterative.
Jean Giraud, I wasn't precise enough. The problem is regarding the flow over weir, not calculation of a flow rate, per se.
Sandro
WroteJean Giraud, I wasn't precise enough. The problem is regarding the flow over weir, not calculation of a flow rate, per se.
1. You calculate mas flow rate for: Nozzle, Venturi.
2. You size orifice plate for given nominal mass flow rate
3. You calculate mass flow rate for a given prefabricated weir.
If you have the mass flow rate from another independent device
per say: partially filled pipe ... you can solve/sanity check.
That is pretentious to sanity the established Standard.
Nothing wrong to sanity the Standard, but sanity $$$$
The biggest Venturi I have been involved 8 ft diameter [$$$$$$..]
It needs the pipe full flow, not partially filled.
ISO-5167 goes up 36" diameter.
From the attached document, be more specific.
Inst_Weir.sm (230.73 KiB) downloaded 1273 time(s).
