Find value of a variable by changing value of another (solve (2) perhaps?)
Find value of a variable by changing value of another (solve (2) perhaps?) - Сообщения
#1 Опубликовано: 22.06.2021 13:24:02
sandros
sandros
I'm trying to make a SMath worksheet for calculating flow over weir. The problem is iterative, i.e. when you calculate it "by hand" you have to estimate some values and then check if your estimation is close enough.
Here is my workbook:
suppressed_weir.sm (79,98 КиБ) скачан 1225 раз(а).
suppressed_weir.pdf (365,79 КиБ) скачан 823 раз(а).
I tried to solve this problem by using "solve (2)" function, but I'm obviously doing something wrong...
Could anyone help me with this?
Cheers,
Sandro
#2 Опубликовано: 22.06.2021 13:42:16
The masflow rate of a weir is not iterative.
https://www.brighthubengineering.com/hydraulics-civil-engineering/65880-open-channel-flow-measurement-5-the-rectangular-weir/
#3 Опубликовано: 22.06.2021 13:52:40
Cheers,
Sandro
Hope this is enough for you.
Solve can't work with units.
Sometimes it just refuses even without units.
Use roots(), FindRoot(), al_nleqsolve() if it fails.
In this order generally.
Regards.
suppressed_weir1.sm (82,41 КиБ) скачан 1225 раз(а).
#4 Опубликовано: 22.06.2021 14:25:22
sandros
sandros
Use roots, FindRoot, al_nleqsolve if it fails.
Regards.
Thank you, overlord, that works exactly as I wanted!
Jean Giraud, I wasn't precise enough. The problem is regarding the flow over weir, not calculation of a flow rate, per se.
Sandro
#5 Опубликовано: 22.06.2021 18:04:22
1. You calculate mas flow rate for: Nozzle, Venturi.
2. You size orifice plate for given nominal mass flow rate
3. You calculate mass flow rate for a given prefabricated weir.
If you have the mass flow rate from another independent device
per say: partially filled pipe ... you can solve/sanity check.
That is pretentious to sanity the established Standard.
Nothing wrong to sanity the Standard, but sanity $$$$
The biggest Venturi I have been involved 8 ft diameter [$$$$$$..]
It needs the pipe full flow, not partially filled.
ISO-5167 goes up 36" diameter.
From the attached document, be more specific.
Inst_Weir.sm (230,73 КиБ) скачан 1273 раз(а).
#6 Опубликовано: 23.06.2021 05:12:27
I am glad to help you exactly as you wanted.
Have a nice day, feel free to ask anything.
Someone shall answer your question as your need.
