i can't match units.
i can't match units. - Messages
#1 Posted: 3/7/2023 12:02:39 AM
soomoon
soomoon
1 likes in 41 posts.
how can i do?
thank you
#2 Posted: 3/7/2023 1:05:19 AM
598 likes in 1,379 posts.
Check your formula thoroughly.
There is a wrong unit calculation.
Lets give 10mm^2 to x.
This equation won't have a result.
Equation can be calculated with this correction.
Given with units of x is mm^2 of course.
For its to be solved, f(x)=y.
And y should be zero.
And if we plot the f(x) function,
You can see y never gets to zero.
So basically, this equation is not solvable.
With given equation and numbers I say.
