i can't match units.
i can't match units. - Сообщения
#1 Опубликовано: 07.03.2023 00:02:39
soomoon
soomoon
1 сообщений из 41 понравились пользователям.
how can i do?
thank you
#2 Опубликовано: 07.03.2023 01:05:19
597 сообщений из 1 377 понравились пользователям.
Check your formula thoroughly.
There is a wrong unit calculation.
Lets give 10mm^2 to x.
This equation won't have a result.
Equation can be calculated with this correction.
Given with units of x is mm^2 of course.
For its to be solved, f(x)=y.
And y should be zero.
And if we plot the f(x) function,
You can see y never gets to zero.
So basically, this equation is not solvable.
With given equation and numbers I say.
