SMath Studio 0.98.6075 (19 August 2016)
SMath Studio 0.98.6075 (19 August 2016) - Messages
#1 Posted: 8/19/2016 12:05:04 PM
2,343 likes in 4,042 posts.
SMath Studio 0.98.6075 available
Latest changes (against SMath Studio 0.98.6073)
  • SS-2368: Units don't match issue fixed happened in several cases for numeric calculation;
  • SS-2366: Showing of Reference Book and Print Preview windows when SMath Studio shown always on top fixed;
  • Plot Region improved for better support of animated graphs created in previous versions of the program;
  • Fixed issues with repeated worksheet evaluation started automatically without any user request (usually happened on complex worksheet open or on complex expression paste);
  • Symbolic engine: Infinity divided by zero is equal to Infinity now (the same as done for Numeric engine);
  • Location of breakpoints corrected on vertical scrollbar when breakpoint(s) set on operands;
  • Displaying current stop when calculation paused corrected when stop is on operand;
  • Empty Missing Plugins dialog appeared sometimes on file open fixed;
  • Meaningless message of Missing Plugins dialog about incorrect version of built-in plugins (MathRegion and AreaRegion) on file open removed;
  • Handling of remove Region operation improved (worksheet recalculated if content of focused MathRegion deleted using Backspace);
  • Paste of math expression (not a MathRegion itself) from Clipboard do not initiate immediate worksheet recalculation anymore;
  • Shortcut key added to Toggle Breakpoint context menu item;
  • Interface translation files updated;
  • Refactoring.
Download
5 users liked this post
Davide Carpi 8/19/2016 12:22:00 PM, sergio 8/19/2016 12:42:00 PM, NDTM Amarasekera 8/19/2016 12:50:00 PM, Radovan Omorjan 8/19/2016 2:27:00 PM, frapuano 8/19/2016 2:35:00 PM
#2 Posted: 8/19/2016 10:02:32 PM
Ryan Freund
Ryan Freund
20 likes in 339 posts.
What does this refer to:
"Shortcut key added to Toggle Breakpoint context menu item"
Thanks!
#3 Posted: 8/20/2016 4:46:17 AM
Sure. Screenshot added above.
#4 Posted: 8/20/2016 12:26:00 PM
Ryan Freund
Ryan Freund
Thank you.
One other thing I've noticed. When using equal sign to display the result of an equation or variable, I usually want to change the units. I used to hit the right arrow three times and it would bring me to the new units "blank space". Now I have to arrow through all the decimals in order to get there. Was this an intended change?
#5 Posted: 8/20/2016 12:40:21 PM
You're welcome.
Nope, seems I just forgot about this behavior during MathRegion code review. Will check it, thank you.
Davide Carpi 8/20/2016 2:22:00 PM
#6 Posted: 8/20/2016 12:47:07 PM
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
Could it be possible then to go to units placeholder immediately when one inserts equal? What's the reason to stay before it?
С уважением, Михаил Каганский
3 users liked this post
Davide Carpi 8/20/2016 2:22:00 PM, sergio 8/20/2016 2:32:00 PM, frapuano 8/21/2016 8:32:00 AM
