SMath Studio 0.98.6075 (19 August 2016)
SMath Studio 0.98.6075 (19 August 2016) - Сообщения
#1 Опубликовано: 19.08.2016 12:05:04
2 343 сообщений из 4 042 понравились пользователям.
Группа: Super Administrator
SMath Studio 0.98.6075 available
Latest changes (against SMath Studio 0.98.6073)
  • SS-2368: Units don't match issue fixed happened in several cases for numeric calculation;
  • SS-2366: Showing of Reference Book and Print Preview windows when SMath Studio shown always on top fixed;
  • Plot Region improved for better support of animated graphs created in previous versions of the program;
  • Fixed issues with repeated worksheet evaluation started automatically without any user request (usually happened on complex worksheet open or on complex expression paste);
  • Symbolic engine: Infinity divided by zero is equal to Infinity now (the same as done for Numeric engine);
  • Location of breakpoints corrected on vertical scrollbar when breakpoint(s) set on operands;
  • Displaying current stop when calculation paused corrected when stop is on operand;
  • Empty Missing Plugins dialog appeared sometimes on file open fixed;
  • Meaningless message of Missing Plugins dialog about incorrect version of built-in plugins (MathRegion and AreaRegion) on file open removed;
  • Handling of remove Region operation improved (worksheet recalculated if content of focused MathRegion deleted using Backspace);
  • Paste of math expression (not a MathRegion itself) from Clipboard do not initiate immediate worksheet recalculation anymore;
  • Shortcut key added to Toggle Breakpoint context menu item;
  • Interface translation files updated;
  • Refactoring.
Download
Davide Carpi 19.08.2016 12:22:00, sergio 19.08.2016 12:42:00, NDTM Amarasekera 19.08.2016 12:50:00, Radovan Omorjan 19.08.2016 14:27:00, frapuano 19.08.2016 14:35:00
#2 Опубликовано: 19.08.2016 22:02:32
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
What does this refer to:
"Shortcut key added to Toggle Breakpoint context menu item"
Thanks!
#3 Опубликовано: 20.08.2016 04:46:17
Sure. Screenshot added above.
#4 Опубликовано: 20.08.2016 12:26:00
Ryan Freund
Ryan Freund
Thank you.
One other thing I've noticed. When using equal sign to display the result of an equation or variable, I usually want to change the units. I used to hit the right arrow three times and it would bring me to the new units "blank space". Now I have to arrow through all the decimals in order to get there. Was this an intended change?
#5 Опубликовано: 20.08.2016 12:40:21
You're welcome.
Nope, seems I just forgot about this behavior during MathRegion code review. Will check it, thank you.
Davide Carpi 20.08.2016 14:22:00
#6 Опубликовано: 20.08.2016 12:47:07
Mike Kaganski
Mike Kaganski
Could it be possible then to go to units placeholder immediately when one inserts equal? What's the reason to stay before it?
С уважением, Михаил Каганский
Davide Carpi 20.08.2016 14:22:00, sergio 20.08.2016 14:32:00, frapuano 21.08.2016 08:32:00
