Fail to run Ubuntu
Fail to run Ubuntu - FATAL UNHANDLED EXCEPTION: System.TypeLoadException - Messages
#1 Posted: 7/22/2012 1:18:49 PM
dapanara
dapanara
0 likes in 1 posts.
Dear All,
I tried to install the program on ubuntu and i got the following error message... anyone could help?
mono ./SMathStudio_Desktop.exe
Unhandled Exception: System.TypeLoadException: Could not load type '.' from assembly 'SMathStudio_Desktop, Version=0.95.4559.3008, Culture=neutral, PublicKeyToken=null'.
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeLoadException: Could not load type '.' from assembly 'SMathStudio_Desktop, Version=0.95.4559.3008, Culture=neutral, PublicKeyToken=null'.
regards,
Daniele
#2 Posted: 7/22/2012 7:30:54 PM
Diego Jarrín
Diego Jarrín
7 likes in 14 posts.
You don´t need to install SMath on Ubuntu, it is a portable executable program that requires the Framework: Mono 2.0 (libmono-winforms-2.0-cil package).
After downloading the libmono-winforms-2.0-cil package, open the terminal in the same folder you downloaded and unziped the SMath Studio version for Linux (https://smath.com/files/Download/NwwZ2) and type:
mono SMathStudio_Desktop.exe
That should work, I use SMath Studio with Linux Mint 9 & 12 (distros based in Ubuntu), so Ubuntu can handle it.
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
