Fail to run Ubuntu
Fail to run Ubuntu - FATAL UNHANDLED EXCEPTION: System.TypeLoadException - Сообщения
#1 Опубликовано: 22.07.2012 13:18:49
dapanara
dapanara
Dear All,
I tried to install the program on ubuntu and i got the following error message... anyone could help?
mono ./SMathStudio_Desktop.exe
Unhandled Exception: System.TypeLoadException: Could not load type '.' from assembly 'SMathStudio_Desktop, Version=0.95.4559.3008, Culture=neutral, PublicKeyToken=null'.
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeLoadException: Could not load type '.' from assembly 'SMathStudio_Desktop, Version=0.95.4559.3008, Culture=neutral, PublicKeyToken=null'.
regards,
Daniele
#2 Опубликовано: 22.07.2012 19:30:54
Diego Jarrín
Diego Jarrín
7 сообщений из 14 понравились пользователям.
You don´t need to install SMath on Ubuntu, it is a portable executable program that requires the Framework: Mono 2.0 (libmono-winforms-2.0-cil package).
After downloading the libmono-winforms-2.0-cil package, open the terminal in the same folder you downloaded and unziped the SMath Studio version for Linux (https://smath.com/files/Download/NwwZ2) and type:
mono SMathStudio_Desktop.exe
That should work, I use SMath Studio with Linux Mint 9 & 12 (distros based in Ubuntu), so Ubuntu can handle it.
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
