f(x, y) - 3D plot and optimal point
f(x, y) - 3D plot and optimal point - Steam Turbine - Messages
#1 Posted: 11/6/2023 12:13:14 AM
Valery Ochkov
Valery Ochkov
67 likes in 708 posts.
I have f(x, y) - thermal efficiency of a steam turbine with two steam extractions for heating feed water depending on the extraction pressures.
Question.
1. How to find the optimal pressure values at which the efficiency will be maximum?
2. Is it possible to build a surface? For now I have two separate 2D graphics.
More https://link.springer.com/book/10.1007/978-3-319-26674-9
2RegP-Ideal-new.sm (94.95 KiB) downloaded 1540 time(s).
#2 Posted: 11/6/2023 12:43:57 AM
Valery Ochkov
Valery Ochkov
No, you cannot replace WaterSteamPro with Cool Prop for water/steam.
WaterSteamPro is a certified program!
Compare please two plots
#3 Posted: 11/7/2023 3:44:54 AM
1,359 likes in 2,273 posts.
I am not familiar with CoolProps but I think I could make a nice 3D plot with Maxima if you provide the smath file
Valery Ochkov 11/7/2023 1:09:00 PM
#4 Posted: 11/7/2023 1:10:43 PM
Valery Ochkov
Valery Ochkov
Thanks, Martin!
Must be someone so
#5 Posted: 11/7/2023 2:53:03 PM
OK but I need a file where the wsp calls are replaced by coolprop ones. Even if plotting doesn't work as expected.
#6 Posted: 11/8/2023 1:05:10 PM
Valery Ochkov
Valery Ochkov
See please attach
2RegP-Ideal-Cool_Prop-95.sm (73.63 KiB) downloaded 1516 time(s).
2RegP-Ideal-Cool_Prop-95.pdf (361.44 KiB) downloaded 910 time(s).
Martin (and all), I am waiting for the solution - 3D-plot and optimal values of p1 and p2.
#7 Posted: 11/8/2023 9:11:41 PM
Just the plot, no optimization yet.
2RegP-Ideal-Cool_Prop-95_Kr.sm (300.35 KiB) downloaded 1520 time(s).
Oscar Campo 11/8/2023 9:22:00 PM, Valery Ochkov 11/8/2023 10:27:00 PM
#8 Posted: 11/9/2023 1:16:22 AM
Valery Ochkov
Valery Ochkov
No optimization yet.
For checking
#9 Posted: 11/9/2023 6:31:08 PM
Agreed: CoolProp is CoolProp.
For quick visit, I use freeware Katmar IAPWS=97 in all sorts of units.
By same token, in Smath, we have lot of water/steam formulas.
What about you tabulate matrix style, then spline/interpolate.
I will be back on your document ... Jean
Valery Ochkov 11/9/2023 6:37:00 PM
#10 Posted: 11/10/2023 1:49:18 PM
Valery Ochkov
Valery Ochkov
#11 Posted: 11/11/2023 1:40:46 AM
... confirmed vs my formula IAPWS-97
#12 Posted: 11/12/2023 2:37:31 AM
For checking
I get slightly different values. Still no automatic optimization because the objective function doesn't translate to Maxima. As a first step I made the function more robust by solving the two equations sequentially instead of simultaneously. In the original version sampling for the plot occasionally failed.
Plot MPa.pdf (219.47 KiB) downloaded 898 time(s).
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (157.12 KiB) downloaded 1538 time(s).
2023-11-11 19_21_55-SMath Solver - [2RegP-Ideal-Cool_Prop-95_Kr_detail.sm_].png
2RegP-Ideal-Cool_Prop-95_Kr_detail.pdf (520.5 KiB) downloaded 871 time(s).
Valery Ochkov 11/12/2023 2:41:00 AM, Alvaro 11/12/2023 9:04:00 AM
#13 Posted: 11/12/2023 2:51:46 AM
Valery Ochkov
Valery Ochkov
Wonderful!
But I dare to note that a real steam turbine unit has up to eight steam extractions from the turbine to regenerative heaters. And not only mixing, but also surface type.
#14 Posted: 11/12/2023 9:07:21 AM
1,138 likes in 1,805 posts.
I get slightly different values. ...
Hi. Using the definition for partial derivatives and a pure numerical solver.
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (162.36 KiB) downloaded 1456 time(s).
3 users liked this post
Martin Kraska 11/12/2023 9:10:00 AM, Valery Ochkov 11/12/2023 2:12:00 PM, Oscar Campo 11/12/2023 6:29:00 PM
#15 Posted: 11/14/2023 2:13:59 AM
Valery Ochkov
Valery Ochkov
