1 страниц (15 вхождений)
f(x, y) - 3D plot and optimal point - Steam Turbine - Сообщения
I have f(x, y) - thermal efficiency of a steam turbine with two steam extractions for heating feed water depending on the extraction pressures.
Question.
1. How to find the optimal pressure values at which the efficiency will be maximum?
2. Is it possible to build a surface? For now I have two separate 2D graphics.
More https://link.springer.com/book/10.1007/978-3-319-26674-9
2RegP-Ideal-new.sm (94,95 КиБ) скачан 1443 раз(а).
Question.
I am not familiar with CoolProps but I think I could make a nice 3D plot with Maxima if you provide the smath file
Valery Ochkov 07.11.2023 13:09:00
OK but I need a file where the wsp calls are replaced by coolprop ones. Even if plotting doesn't work as expected.
WroteOK but I need a file where the wsp calls are replaced by coolprop ones. Even if plotting doesn't work as expected.
See please attach
2RegP-Ideal-Cool_Prop-95.sm (73,63 КиБ) скачан 1407 раз(а).
2RegP-Ideal-Cool_Prop-95.pdf (361,44 КиБ) скачан 831 раз(а).
Martin (and all), I am waiting for the solution - 3D-plot and optimal values of p1 and p2.
WroteNo, you cannot replace WaterSteamPro with Cool Prop for water/steam.
WaterSteamPro is a certified program!
Agreed: CoolProp is CoolProp.
For quick visit, I use freeware Katmar IAPWS=97 in all sorts of units.
By same token, in Smath, we have lot of water/steam formulas.
What about you tabulate matrix style, then spline/interpolate.
I will be back on your document ... Jean
Valery Ochkov 09.11.2023 18:37:00
WroteWroteNo, you cannot replace WaterSteamPro with Cool Prop for water/steam.
... confirmed vs my formula IAPWS-97
I get slightly different values. Still no automatic optimization because the objective function doesn't translate to Maxima. As a first step I made the function more robust by solving the two equations sequentially instead of simultaneously. In the original version sampling for the plot occasionally failed.
Plot MPa.pdf (219,47 КиБ) скачан 805 раз(а).
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (157,12 КиБ) скачан 1431 раз(а).
![2023-11-11 19_21_55-SMath Solver - [2RegP-Ideal-Cool_Prop-95_Kr_detail.sm_].png](/ru-RU/files/Download/GSNxMg/2023-11-11-19_21_55-SMath-Solver---[2RegP-Ideal-Cool_Prop-95_Kr_detail.sm_].png)
2RegP-Ideal-Cool_Prop-95_Kr_detail.pdf (520,5 КиБ) скачан 805 раз(а).
Wonderful!
But I dare to note that a real steam turbine unit has up to eight steam extractions from the turbine to regenerative heaters. And not only mixing, but also surface type.
WroteI get slightly different values. ...
Hi. Using the definition for partial derivatives and a pure numerical solver.
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (162,36 КиБ) скачан 1361 раз(а).
Martin Kraska 12.11.2023 09:10:00, Valery Ochkov 12.11.2023 14:12:00, Oscar Campo 12.11.2023 18:29:00
![2023-11-08 15_08_23-SMath Solver - [2RegP-Ideal-Cool_Prop-95_Kr.sm_].png](/ru-RU/files/Download/KZD5C6/2023-11-08-15_08_23-SMath-Solver---[2RegP-Ideal-Cool_Prop-95_Kr.sm_].png)
