Custom Function Plugin Error in SS 6520
Custom Function Plugin Error in SS 6520 - Messages
#1 Posted: 11/8/2017 9:01:34 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
I am experiencing problem in installing CustomFunctions Plugin in SS 6520 (07/11/2017).
Even some items {(such as cases(), abs()}in the Function Index of Reference book have problems.
I am using Win 10 64 bit latest update.
Pl test the attached example.
Small Dams Flood Routing Ex-Program Method-Original-Simple3.sm (863.28 KiB) downloaded 1508 time(s).
3 users liked this post
Radovan Omorjan 11/8/2017 9:37:00 AM, sergio 11/8/2017 1:17:00 PM, frapuano 11/8/2017 3:07:00 PM
#2 Posted: 11/8/2017 9:37:35 AM
Confirmed as well,
NDTM Amarasekera 11/9/2017 11:47:00 PM
#3 Posted: 11/8/2017 3:49:41 PM
Thank you, I'll fix it ASAP. As usual please be patient and keep reporting issues
#4 Posted: 11/9/2017 8:57:09 AM
They might be related to the new rendering system. I miss the issues with abs() (not related to CustomFunctions, though), could you post a screenshoot? Thanks in advance.
#5 Posted: 11/9/2017 11:45:13 AM
NDTM Amarasekera
NDTM Amarasekera
Thanks David. Following Screenshots(SC) are taken before updating Custom Functions Plugin.
SC 1: Selected Function Index of Reference Book.
SC 2: abs() selected and before updating Custom Functions.
I will let you know the situation after updating Custom Functions.
ndtma
#6 Posted: 11/9/2017 11:56:14 AM
"The mind is everything. What you think you become."
Descartes said it otherwise: "je pense, donc je suis"
First intelligent expression since mankind !
#7 Posted: 11/9/2017 12:17:10 PM
NDTM Amarasekera
NDTM Amarasekera
This was said by Lord Buddha about 2600 years ago. I only quoted it.
Thanks.
#8 Posted: 11/9/2017 1:27:16 PM
Ah yes, there is a Conjugate() function in that worksheet
