Custom Function Plugin Error in SS 6520
Custom Function Plugin Error in SS 6520 - Сообщения
#1 Опубликовано: 08.11.2017 09:01:34
NDTM Amarasekera
NDTM Amarasekera
I am experiencing problem in installing CustomFunctions Plugin in SS 6520 (07/11/2017).
Even some items {(such as cases(), abs()}in the Function Index of Reference book have problems.
I am using Win 10 64 bit latest update.
Pl test the attached example.
Small Dams Flood Routing Ex-Program Method-Original-Simple3.sm (863,28 КиБ) скачан 1544 раз(а).
Radovan Omorjan 08.11.2017 09:37:00, sergio 08.11.2017 13:17:00, frapuano 08.11.2017 15:07:00
#2 Опубликовано: 08.11.2017 09:37:35
Confirmed as well,
NDTM Amarasekera 09.11.2017 23:47:00
#3 Опубликовано: 08.11.2017 15:49:41
Thank you, I'll fix it ASAP. As usual please be patient and keep reporting issues
#4 Опубликовано: 09.11.2017 08:57:09
They might be related to the new rendering system. I miss the issues with abs() (not related to CustomFunctions, though), could you post a screenshoot? Thanks in advance.
#5 Опубликовано: 09.11.2017 11:45:13
NDTM Amarasekera
NDTM Amarasekera
Thanks David. Following Screenshots(SC) are taken before updating Custom Functions Plugin.
SC 1: Selected Function Index of Reference Book.
SC 2: abs() selected and before updating Custom Functions.
I will let you know the situation after updating Custom Functions.
Файл не найден. Файл не найден.
ndtma
#6 Опубликовано: 09.11.2017 11:56:14
"The mind is everything. What you think you become."
Descartes said it otherwise: "je pense, donc je suis"
First intelligent expression since mankind !
#7 Опубликовано: 09.11.2017 12:17:10
NDTM Amarasekera
NDTM Amarasekera
This was said by Lord Buddha about 2600 years ago. I only quoted it.
Thanks.
#8 Опубликовано: 09.11.2017 13:27:16
Ah yes, there is a Conjugate() function in that worksheet
