1 Pages (10 items)
[SS-13] Matrix Insert Row or Column - Some data sets that were transcribed are missing insormation - Messages
#1 Posted: 4/12/2018 2:10:56 PM
Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) as I've tri. Am I missing anything?
Matrix -Insert Row or Column.sm (5.2 KiB) downloaded 1691 time(s).
#2 Posted: 4/12/2018 2:19:30 PM
Cutrrently not possible: [SS-13]
#3 Posted: 4/12/2018 2:23:48 PM
Thank you
Just added a vote to this item
#4 Posted: 4/12/2018 3:42:29 PM
Easy/simple ... it's ADD not INSERT
Matrix -Insert Row or Column.sm (12.53 KiB) downloaded 1775 time(s).
#5 Posted: 4/12/2018 8:35:51 PM
WroteAdding a row or column in Mathcad, mid Matrix, was simple.
In SMath, I cannot copy portions of the matrix to move the information (all or nothing) ...
Simply => submatrix !
#6 Posted: 4/12/2018 8:37:35 PM
simply submatrix !
#7 Posted: 4/13/2018 3:26:21 AM
You can use this tool. It also allows conversion between Excel and Smath.
Smath Tools:
https://smath.info/wiki/Tools.ashx
Smath Tools:
#8 Posted: 4/13/2018 9:04:16 AM
WroteYou can use this tool
Dead like stone, better use Smath tool ! page 14
Utilities Matrix Treasury_0 Copy.sm (496.62 KiB) downloaded 1747 time(s).
#9 Posted: 4/16/2018 5:24:55 PM
Jean,
Sometimes your convoluted solutions really do inspire ... when I understand them
Here is a work around that works for me. I did NOT try it as an insert to column or row index 1 as I assume these exist. If those are needed, I guess we use augment. At the end of a matrix, we can just pull the handle. RS_Insert cols_rows to Matrices.smz (6.87 KiB) downloaded 1822 time(s).
Thank you
Thank you
#10 Posted: 4/16/2018 9:08:50 PM
Pad(M,nc,nr) ... padding a matrix has the meaning centered [nc,nr] insertion,
reserved for Fourier 'ifft'... why did you remove it.
For common work, rater use InsertCol/InsertRow.
RS_Insert cols_rows to Matrices(1).sm (47.58 KiB) downloaded 1776 time(s).
1 Pages (10 items)
