[SS-13] Matrix Insert Row or Column
[SS-13] Matrix Insert Row or Column - Some data sets that were transcribed are missing insormation - Сообщения
#1 Опубликовано: 12.04.2018 14:10:56
Ruben Sidranski
Ruben Sidranski
Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) as I've tri. Am I missing anything?
Matrix -Insert Row or Column.sm (5,2 КиБ) скачан 1652 раз(а).
#2 Опубликовано: 12.04.2018 14:19:30
Cutrrently not possible: [SS-13]
#3 Опубликовано: 12.04.2018 14:23:48
Ruben Sidranski
Ruben Sidranski
Thank you Just added a vote to this item
#4 Опубликовано: 12.04.2018 15:42:29
Easy/simple ... it's ADD not INSERT
Matrix -Insert Row or Column.sm (12,53 КиБ) скачан 1736 раз(а).
#5 Опубликовано: 12.04.2018 20:35:51
In SMath, I cannot copy portions of the matrix to move the information (all or nothing) ...
Simply => submatrix !
#6 Опубликовано: 12.04.2018 20:37:35
simply submatrix !
#7 Опубликовано: 13.04.2018 03:26:21
Martin_B
Martin_B
22 сообщений из 84 понравились пользователям.
You can use this tool. It also allows conversion between Excel and Smath.
Smath Tools:
https://smath.info/wiki/Tools.ashx
#8 Опубликовано: 13.04.2018 09:04:16
Dead like stone, better use Smath tool ! page 14
Utilities Matrix Treasury_0 Copy.sm (496,62 КиБ) скачан 1699 раз(а).
#9 Опубликовано: 16.04.2018 17:24:55
Ruben Sidranski
Ruben Sidranski
Jean,
Sometimes your convoluted solutions really do inspire ... when I understand them
Here is a work around that works for me. I did NOT try it as an insert to column or row index 1 as I assume these exist. If those are needed, I guess we use augment. At the end of a matrix, we can just pull the handle. RS_Insert cols_rows to Matrices.smz (6,87 КиБ) скачан 1753 раз(а).
Thank you
#10 Опубликовано: 16.04.2018 21:08:50
Pad(M,nc,nr) ... padding a matrix has the meaning centered [nc,nr] insertion,
reserved for Fourier 'ifft'... why did you remove it.
For common work, rater use InsertCol/InsertRow.
RS_Insert cols_rows to Matrices(1).sm (47,58 КиБ) скачан 1744 раз(а).
