chart with 3 axis Y
chart with 3 axis Y - Messages
#1 Posted: 5/6/2022 7:51:10 AM
D D
D D
0 likes in 8 posts.
Is it possible to make such a chart with three Y axes on a single chart?
something like this
https://ibb.co/JcRn2B9
#2 Posted: 5/6/2022 8:01:53 AM
fedeghi
fedeghi
25 likes in 112 posts.
In case you want to have more than one Y value axis, in"XY Plugin" you can set two different Y axis scales: some traces will refer to Y1, some to Y2
I think that there is not "out of the box" tool to have three or more Y axis.
#3 Posted: 5/6/2022 8:19:07 AM
598 likes in 1,379 posts.
It is not possible to show three separate y-axis as fedeghi already told.
However, you can show three function on a single chart with sys().
#4 Posted: 5/6/2022 10:41:27 AM
You can have as many as you want of fake style like the image.
Create Y's as image and slide close to the plot.
You can do lot more Professional ... associate each graph with Nodes Labels.
Cheers ... Jean.
#5 Posted: 5/6/2022 11:05:05 AM
1,547 likes in 1,861 posts.
Using X-Y Plot Region, you can simulate your graph with any number of axes, but needs some programming like in this example.
XYPlot. Linear polar.sm (61.18 KiB) downloaded 1034 time(s).
#6 Posted: 5/6/2022 12:04:31 PM
1,111 likes in 1,788 posts.
Hi. Also, you can do that in Plotly:
https://plotly.com/chart-studio-help/excel/three-y-axes/
and then put it into SMath, but I don't know how to use the plugin, or if it is available:
https://en.smath.com/forum/yaf_postst17372_Plotly.aspx
#7 Posted: 5/6/2022 12:19:50 PM
... omitted details:
1. X_Y does not accept Nodes Labels.
2. X_Y splines nicely data set, QuickPlot NOT
3. Both X_Y, QuickPlot accept 3D isometric axes.
#8 Posted: 5/6/2022 4:02:34 PM
CBG
CBG
78 likes in 312 posts.
It is possible to use a graph with 2 Y-axes as shown in the image.
#9 Posted: 5/8/2022 5:37:38 PM
... as many as you want horizontal/vertical,
disposed inner wrt the Quick Plot
otherwise outside X_Y past build-in default 2.
Utilities XY Label Graph MORE.sm (35.86 KiB) downloaded 1056 time(s).
#10 Posted: 5/9/2022 8:18:23 AM
... from this factory demo.
Utilities XY Label Graph Y.sm (22.32 KiB) downloaded 990 time(s).
#11 Posted: 5/9/2022 10:21:01 AM
... for whatever end use, add margins/calipers.
Utilities XY Label Graph Y factory.sm (41.03 KiB) downloaded 1059 time(s).
#12 Posted: 5/10/2022 2:05:02 PM
D D
D D
0 likes in 8 posts.
thanks for helping everyone. I used plotly and coped with the charts.
#13 Posted: 5/10/2022 11:48:21 PM
CBG
CBG
Hello
I think your graph could be like this
Three_exes_Graf.sm (32.97 KiB) downloaded 1041 time(s).
