chart with 3 axis Y
chart with 3 axis Y - Сообщения
#1 Опубликовано: 06.05.2022 07:51:10
D D
D D
Is it possible to make such a chart with three Y axes on a single chart?
something like this
https://ibb.co/JcRn2B9
#2 Опубликовано: 06.05.2022 08:01:53
fedeghi
fedeghi
25 сообщений из 112 понравились пользователям.
In case you want to have more than one Y value axis, in"XY Plugin" you can set two different Y axis scales: some traces will refer to Y1, some to Y2
I think that there is not "out of the box" tool to have three or more Y axis.
#3 Опубликовано: 06.05.2022 08:19:07
It is not possible to show three separate y-axis as fedeghi already told.
However, you can show three function on a single chart with sys().
#4 Опубликовано: 06.05.2022 10:41:27
You can have as many as you want of fake style like the image.
Create Y's as image and slide close to the plot.
You can do lot more Professional ... associate each graph with Nodes Labels.
Cheers ... Jean.
#5 Опубликовано: 06.05.2022 11:05:05
Using X-Y Plot Region, you can simulate your graph with any number of axes, but needs some programming like in this example.
XYPlot. Linear polar.sm (61,18 КиБ) скачан 1126 раз(а).
#6 Опубликовано: 06.05.2022 12:04:31
1 124 сообщений из 1 796 понравились пользователям.
Hi. Also, you can do that in Plotly:
https://plotly.com/chart-studio-help/excel/three-y-axes/
and then put it into SMath, but I don't know how to use the plugin, or if it is available:
https://en.smath.com/forum/yaf_postst17372_Plotly.aspx
#7 Опубликовано: 06.05.2022 12:19:50
... omitted details:
1. X_Y does not accept Nodes Labels.
2. X_Y splines nicely data set, QuickPlot NOT
3. Both X_Y, QuickPlot accept 3D isometric axes.
#8 Опубликовано: 06.05.2022 16:02:34
CBG
CBG
It is possible to use a graph with 2 Y-axes as shown in the image.
#9 Опубликовано: 08.05.2022 17:37:38
... as many as you want horizontal/vertical,
disposed inner wrt the Quick Plot
otherwise outside X_Y past build-in default 2.
Utilities XY Label Graph MORE.sm (35,86 КиБ) скачан 1159 раз(а).
#10 Опубликовано: 09.05.2022 08:18:23
... from this factory demo.
Utilities XY Label Graph Y.sm (22,32 КиБ) скачан 1098 раз(а).
#11 Опубликовано: 09.05.2022 10:21:01
... for whatever end use, add margins/calipers.
Utilities XY Label Graph Y factory.sm (41,03 КиБ) скачан 1159 раз(а).
#12 Опубликовано: 10.05.2022 14:05:02
D D
D D
thanks for helping everyone. I used plotly and coped with the charts.
#13 Опубликовано: 10.05.2022 23:48:21
CBG
CBG
Hello
I think your graph could be like this
Three_exes_Graf.sm (32,97 КиБ) скачан 1135 раз(а).
