1 Pages (11 items)
Newton method - Messages
#1 Posted: 4/8/2023 4:07:23 PM
I cannot use the roots function and must use one old good simple method by Newton.
What can you say about it?
Newton-Eng.docx (1.07 MiB) downloaded 1000 time(s).
Martin Kraska 4/9/2023 8:50:00 AM
#2 Posted: 4/9/2023 8:56:19 AM
Very nice.
I had problems when reproducing your 2D version. Depending on initial guess I got errors "requested matrix element does not exist". The situation seemed to improve a little by pre-allocating the vectors X and Y yet it didn't become really robust.
So instead of assigning to j+1 elements I used augment() to add new points to the iteration history.
This is the original version:
Newton2D.sm (21.4 KiB) downloaded 1577 time(s).
And this is the modified version.
Newton2Da.sm (19.03 KiB) downloaded 1696 time(s).
#3 Posted: 4/9/2023 2:27:18 PM
Wrote... can't find 2nd root
2nd root confirmed exact.
Solve(f,q,x0,x1,TOL) Copy.sm (162.62 KiB) downloaded 1693 time(s).
#4 Posted: 4/9/2023 2:33:35 PM
#5 Posted: 4/9/2023 6:19:38 PM
Another way, keeping the mathematical formulation and the iteration algorithm separate. As here.
Newton2Da.sm (13.34 KiB) downloaded 1752 time(s).
#6 Posted: 4/10/2023 12:25:58 PM
Thanks Alvaro, added to my next Samples visit.
Take care ... Jean
Take care ... Jean
#7 Posted: 4/10/2023 4:21:38 PM
#8 Posted: 4/10/2023 8:29:31 PM
WroteI cannot use the roots function and must use one old good simple method by Newton.
An old vintage in Smath ... two examples.
Take care Valery ... Jean.
Solve_roost f1(x,y). f2(x,y).sm (27.42 KiB) downloaded 1688 time(s).
#9 Posted: 4/11/2023 2:21:16 PM
Two variations added.
Newton2Da. v2.sm (38.35 KiB) downloaded 1690 time(s).
Newton2Da. v2.pdf (152.11 KiB) downloaded 1159 time(s).
sergio 5/3/2023 2:29:00 PM
#10 Posted: 5/3/2023 12:37:31 AM
WroteTwo variations added.
From my future article
Если уравнений не два, а три, то матрица Якоби будет состоять из трёх строк и трёх столбцов. При этом графически отображать решение придётся не двумя кривыми, а тремя поверхностями на 3D-графике, причём их взаимное пересечение и будет отмечать решение (задание читателю).
Слабо!
Alvaro 5/3/2023 3:21:00 AM
#11 Posted: 5/3/2023 12:02:25 PM
You may find this Treasury useful/productive.
Solve(f,q,x0,x1,TOL) Copy.sm (300.16 KiB) downloaded 1715 time(s).
1 Pages (11 items)
