[SS-4609] No XML start tag open
[SS-4609] No XML start tag open - Missing XML start tag - Messages
#1 Posted: 10/3/2019 12:43:28 PM
Ryan Freund
Ryan Freund
20 likes in 339 posts.
Can anyone help recover this file? It says that there is no XML start tag open. See attached
Thanks in advance!
New Beam Design.sm (191.34 KiB) downloaded 1523 time(s).
#2 Posted: 10/3/2019 4:02:08 PM
Arie
Arie
94 likes in 285 posts.
Thanks in advance!
Fixed.
New_Beam_Design_fixed_alyles.sm (200.36 KiB) downloaded 1560 time(s).
For anyone curious. I ended up fixing an empty tag for this particular area title to have an explicit start and end tag. I don't know enough about the SMath parser to know why this is a problem. I didn't try deleting it.
Problem:
Solution
sergio 10/4/2019 4:04:00 AM, Davide Carpi 10/4/2019 12:11:00 PM
#3 Posted: 10/3/2019 4:36:23 PM
Ryan Freund
Ryan Freund
Thanks Alyles!
#4 Posted: 5/20/2020 12:25:47 PM
eswte
eswte
0 likes in 8 posts.
Problem:
Solution
I had the same problem, how did you find the error? There are so much lines y don't know how to find the error
#5 Posted: 5/20/2020 3:36:49 PM
If you have an editor that supports syntax highlighting for xml is easier, usually you can collapse blocks of code and you can spot where something is wrong. You can try to check yourself using programs such as notepad++ or visual studio code.
