Solution of equations (find the roots)
Solution of equations (find the roots) - Messages
#21 Posted: 7/6/2009 12:51:40 PM
Smfan
Smfan
0 likes in 7 posts.
Every little progress with hard work behind-the-scenes
#22 Posted: 7/6/2009 8:26:45 PM
jakobg
jakobg
0 likes in 21 posts.
First of all, again (and again!!) thanks for your work!
Omorr your posts and discussions are really very helpful, thanks for this too!
Regarding the plot and finding roots question, I had a similar problem, a few weeks ago, and solved it with a little function scaling.
So in this case just multiply the function with e.g. 1000 and there will be no problem of locating the roots in the plot. And since you scale just the y-axis the value of x won't change. It is really a simple way around.
Unforunatelly I haven't figured out how to post screens and the live version is not capable of ploting so I can just try to explain it this way.
@ smath:
I don't know if it is really a bug, but if I delete any variable (or text) in Smath Live Mode using the DEL Button a . (Dot) appears somewhere in the page. If I use the Backspace Button to delete it works like expected (so nothing is created).
I can reproduce this issue on Linux and Windows (both with Firefox-browser).
Thanks again!
Ciao Jakob
#23 Posted: 7/6/2009 8:46:04 PM
Thanks again!
Ciao Jakob
You are very welcome Jakob,
and thank you for the hint about scaling - simple but very useful !
I hope that SMath will have the posibilitie in some subsequent version about separate axis scaling.
P.S. @smath will need to explain to you how to put the images and other stuf here
#24 Posted: 7/7/2009 11:55:27 AM
ZioZione
ZioZione
0 likes in 5 posts.
Hi smath,
just a little thank for new 0.82 Portable version.
Now all "Xenocode" folder contents is saved into application folder...
For the empty registry key, I think there is nothing to do, but I noticed it just for the sake of completeness (and pedantry...).
Also if you found other bugs (that I wish you to quickly fix), please consider fixed this one.
ZioZione
#25 Posted: 7/7/2009 12:18:34 PM
2,343 likes in 4,057 posts.
Hi smath,
ZioZione
Ok. But I want to mention, that real 0.82 release will be available in a couple of days. Links here was published to the Release Candidate only - it have some critical GUI bugs, that already fixed in newer internal build.
#26 Posted: 7/9/2009 7:05:22 AM
ZioZione
ZioZione
0 likes in 5 posts.
Hi smath,
ZioZione
Hi smath,
yes, of course, I won't intend to use it in a Production environment...
In the meanwhile I just downloaded the latest release... Thank you again!
ZioZione
P.S. If you want to collaborate with winPenPack for a TOTALLY PORTABLE (I mean, without the empty registry key) SMath, through X-Launcher (our universal launcher), you are, of course, welcome... We prefer to deal with Open Source only software, but if you agree with our license I don't think that will be any problem.
#27 Posted: 11/5/2011 6:02:05 AM
geeknick
geeknick
0 likes in 3 posts.
It seems to be very good tool for the students like me because of i am so weak in this subject and i want to use this algebra problem solver. but i want to know that it is useful in algebra or any other branch of mathematics. can i use this tool to solve quadratic equations?? please give me reply regarding algebra problem solver....
#28 Posted: 11/5/2011 8:17:00 AM
Yes, you can do lots of algebra things in SMath. Se the Tutorils page on thr Wiki, please.
#29 Posted: 4/16/2015 11:10:09 AM
robinson
robinson
0 likes in 3 posts.
Hi
Could you help me with this? I tried to solve this cubic equation
A=solve(x^3+A*x^2+B*x+C=0,x)
where A=5, B=4, C=0, the answer give me only two roots 5 and 0, instead of three. The right answer is -1, 0, 5.
Could you explain me what can I do or what is wrong?
Thanks
#30 Posted: 4/16/2015 11:44:55 AM
No issues here
#31 Posted: 4/16/2015 3:44:11 PM
robinson
robinson
0 likes in 3 posts.
Thank-you Davide
I downloaded the file, but something is wrong because, I only saw two roots
cubic 1
However with other values is ok
cubic2
Robinson
#32 Posted: 4/16/2015 6:20:16 PM
I see... BTW also the cloud version gives 3 roots
Yuo can try to check if something is different in the global settings (Tools > Options... > Calculation)
#33 Posted: 4/16/2015 8:09:42 PM
robinson
robinson
0 likes in 3 posts.
Now is working. I changed Roots (range).
Thank you for your help
Best Regards,
Robinson
#34 Posted: 8/9/2015 11:25:24 PM
Smath Roots is underdesigned on several counts:
1. The unique Newton-Raphtson does not cope on horizontal/vertical runs of the function
Nothing you can do for two reasons:
1. Smath is very granualar compared to Mathcad 11, 2001i, 8 Pro.
2. Smath does not have TOL, CTOL
3. I figure Smath does not manage Roots because Maxima does not manage.
Suggestion: crack Mathcad 11 root code
#35 Posted: 8/13/2015 12:06:32 AM
Here are your two plots c/w the roots shown on graph.
I have used the 'Solve Quick' in separate sheets not
to confuse solve[f(x),x] with the two differents
search range. Handling graphs are very easy, just a
matter of adjusting each direction [X,Y] separately.
Your solve with bracketed search range is perfect too !
#36 Posted: 8/13/2015 12:26:32 AM
Post again
#37 Posted: 8/13/2015 12:33:16 AM
It wants some wording before attaching ...
#38 Posted: 8/13/2015 10:33:12 PM
Basile
Basile
8 likes in 172 posts.
How do you type the entries in the rho1 and rho2 entries in parentheseis?
Basile
#39 Posted: 8/20/2015 11:28:50 PM
Collab,
Your turmoil is solved. Always plot before you attempt more maths.
#40 Posted: 8/22/2015 12:56:11 AM
Is that so: 20559 viewed that image solution ?
True, sometimes 'solving' is a bit monkey business.
Read more: in the minute I will attach the Quaternion rotation in "Samples".
It gave me hard time, but works fine enough.
Nice forum "Powered by YAF.NET" ... unbelievable, it works on the click,
not like the dummy PTC Mathcad Community that I shared after Mathsoft Collaboratory.
Mathcad PTC comunity was not accessible or very slow every day between hours
22 and about 02 in the morning and dead during big sport competitions, elections ...
