error in a system of equations
error in a system of equations - impossible to get or set an item because it does not exist - Messages
#1 Posted: 11/5/2019 2:02:37 PM
Ale16595
Ale16595
0 likes in 35 posts.
Hi to everyone
I am having difficulty solving a linear system like in the picture.
the error says:"impossible to get or set an item because it does not exist"
does anyone know where the error can be and how to solve this problem?
Thanks in advance
#2 Posted: 11/5/2019 3:08:12 PM
127 likes in 342 posts.
"roots" does not work with the units. You must adimensionare equations, or you can try the other features present in the plugin (eg "FindRoot" present "Nonlinear solvers" plugin)
#3 Posted: 11/5/2019 3:52:23 PM
Ale16595
Ale16595
I tried another function but it still gives me an error...
#4 Posted: 11/5/2019 11:57:28 PM
It's a huge system, and generally does not accept all initials same.
I would zap units first. This kind of solving should have it be
solved from P & P [Pain & Prestige] as it reflects real project
that does come out of the blue. Even Mathcad Given/Find may fail
or pedal through constrain.
Attach the work sheet ... some source reference as well.
#5 Posted: 11/6/2019 2:25:20 AM
Ale16595
Ale16595
here is the spreadsheet
calcoli.sm (46.18 KiB) downloaded 1042 time(s).
it is a system of equations derived from the condition of dynamic equilibrium in the stationary curve motion of a bicycle
#6 Posted: 11/6/2019 4:16:32 AM
1,357 likes in 2,271 posts.
Equations 3 and 4 probably demand different values for N.r+N.f So there is no solution.
If the system has a solution, the function Solve() from Maxima plugin might find it.
sergio 11/6/2019 6:47:00 AM
#7 Posted: 11/6/2019 3:20:34 PM
1. equalities [1,2,3] are consistant 'N'
2. equalities [4,5,6] are inconsistant 'mixed units'
calcoli.sm (52.58 KiB) downloaded 998 time(s).
You must make the system consitant before attempting solve.
#8 Posted: 11/6/2019 3:35:50 PM
Ale16595
Ale16595
I tried to use the solve function but it still gives me an error saying that S is not defined
#9 Posted: 11/6/2019 3:47:31 PM
Did you read my reply just before your visit ?
#10 Posted: 11/6/2019 4:20:21 PM
Ale16595
Ale16595
sorry, when I wrote, I didn't notice your message
#11 Posted: 11/10/2019 11:11:18 PM
1,124 likes in 1,796 posts.
Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
calcoli.sm (50.31 KiB) downloaded 1053 time(s).
#12 Posted: 11/11/2019 7:37:20 AM
Ale16595
Ale16595
Hi, thanks for the reply, but I think I found the error. The system I wrote has two linearly dependent equations, and for this reason it cannot find a solution.
I will have to modify the whole problem.
#13 Posted: 11/11/2019 2:55:47 PM
Hello Alvaro,
The attached CSTR [SS 6179] example is offered differently,
it is initialized from random guesses: success.
Solve al_nleqsolve CSTR.sm (38.81 KiB) downloaded 1024 time(s).
Alvaro 11/12/2019 1:29:00 PM
#14 Posted: 11/12/2019 1:29:59 PM
Hello Alvaro,
Hi Jean. Thanks, very interesting.
