1 Pages (14 items)
Phasor - Messages
#1 Posted: 5/18/2019 8:02:12 PM
I need to draw phasors (lines-vectors) for AC circuit analysis.
- Line from origin to a point.
- Line from a point to another
The magnitude and the angle or Real and Imaginary parts are known.
Is there any related example?
Thank you,
Basile
Thank you,
Basile
#2 Posted: 5/19/2019 10:00:57 AM
#3 Posted: 5/20/2019 1:05:14 AM
Thank you Jean.
Any way to use different colour for some segments?
Put an arrow or a circle at the end?
Have a text to identify each segment?
Basile
Basile
#4 Posted: 5/20/2019 2:25:58 AM
You can use X-Y Plot Region for this.
XYPlot. Draw shapes.sm (19.85 KiB) downloaded 3046 time(s).
XYPlot. Draw shapes.pdf (92.91 KiB) downloaded 2060 time(s).
#5 Posted: 5/20/2019 9:24:12 AM
WroteThank you Jean.
Basile
Hello Basile,
You should be able to build your circuit with the attached.
Make something, attach and we will add text if you can't.
Circle_rkfixed Arrow.sm (27.63 KiB) downloaded 1117 time(s).
2D Util Bar Arrow Model.sm (22.97 KiB) downloaded 1097 time(s).
Circle_rkfixed Clock.sm (23.28 KiB) downloaded 1136 time(s).
#6 Posted: 5/22/2019 10:52:49 AM
Basile
Hello, Basile
On that one you can do a bit more.
Too much may be too much, isn't ?
Maths Polygon.sm (17.1 KiB) downloaded 1122 time(s).
#7 Posted: 5/23/2019 12:22:45 PM
Hello Jean and Uni,
Why the Lv is not defined?
I express the matrices as function.
And then the vectors evaluate!
What are the red squares to the right?
It looks that this approach of drawing vectors is a begging.
I shall work on it.
Thank you,
BasilePage2-error.sm (12.71 KiB) downloaded 1214 time(s).
I shall work on it.
Thank you,
#8 Posted: 5/23/2019 8:32:28 PM
WroteWhat are the red squares to the right?
Red square in the scroll bar points at the errors in the document.
More elegant arrows proposed.
Page2-error.sm (8.34 KiB) downloaded 1265 time(s).
NDTM Amarasekera 5/26/2019 5:25:00 AM
#9 Posted: 5/24/2019 3:09:24 PM
Hi Jean,
The arrows fail when the length of the vector changes.
I have tried as a percentage of length but does not look nice.
Scaling the vectors to always be one but will loose real values
Any good idea?
Is there a way to auto-scale the 2D plot or X-Y plot?
One of the vectors is out of the visual plane.
Thanks,
Basile
Any good idea?
Thanks,
Basile
#10 Posted: 5/24/2019 3:19:13 PM
As I said before:
WroteHow about a simple arrow?
WroteI do not know how to do it better. The arrow should look good in different scales and in its own size.
#11 Posted: 5/24/2019 5:35:33 PM
WroteAny good idea?
None of the quick plot or X_Y plot can be made X, Y directions scalable
similar to Mathcad 11 ... to me: useless.
From an original X_Y plot creation, stretch by handles respect aspect ratio.
If you modify the X, Y directions [max/min], apply close enough HL, HW ratio.
Page2-error (1).sm (11.66 KiB) downloaded 1275 time(s).
#12 Posted: 5/24/2019 10:44:11 PM
3 users liked this post
NDTM Amarasekera 5/24/2019 11:22:00 PM, frapuano 5/25/2019 2:46:00 AM, Вячеслав Мезенцев 5/25/2019 6:08:00 AM
#13 Posted: 5/25/2019 9:24:37 PM
With both arrow heads, based on Jean's method.
Thank you Jean.
Both Arrows.sm (30.49 KiB) downloaded 1081 time(s).
#14 Posted: 5/26/2019 12:52:40 AM
Why I am getting errors when load your file?
The latest Stable: SMath Studio 0.99.7030 (01 April 2019)
At the end I am able to open the file.
I do the same with two arrows 2π apart, but yours is more elegant.
Basile
Basile
1 Pages (14 items)
