Remove 'disable calculation' symbol
Remove 'disable calculation' symbol - Doobert - Messages
#1 Posted: 12/7/2012 5:41:01 PM
Doobert
Doobert
0 likes in 1 posts.
I have to prove a concept mathematically so I have lots of equations that don't get calculated, just showing my work. I disabled the calculations but the little square appears in the upper right corner to let me know its disabled. When I show someone they think its a symbol that should mean something to them. Is there any way to remove these symbols? Even if it only is removed when you save an image that would be great.
#2 Posted: 12/8/2012 2:44:21 AM
You have another option if you just want to represent the equations without calculating them. Just use Boolean equal to (CTRL+=).
A simple example:
[MATH=eng]{a*5}/100≡{b*2}/3≡1/sqrt(c-20)[/MATH]
