Remove 'disable calculation' symbol
Remove 'disable calculation' symbol - Doobert - Сообщения
#1 Опубликовано: 07.12.2012 17:41:01
Doobert
Doobert
I have to prove a concept mathematically so I have lots of equations that don't get calculated, just showing my work. I disabled the calculations but the little square appears in the upper right corner to let me know its disabled. When I show someone they think its a symbol that should mean something to them. Is there any way to remove these symbols? Even if it only is removed when you save an image that would be great.
#2 Опубликовано: 08.12.2012 02:44:21
You have another option if you just want to represent the equations without calculating them. Just use Boolean equal to (CTRL+=).
A simple example:
[MATH=eng]{a*5}/100≡{b*2}/3≡1/sqrt(c-20)[/MATH]
