1 Pages (7 items)
Problem with integral (again) - Definite Integral - Messages
#1 Posted: 12/15/2022 12:03:46 PM
Hi!
I have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem?
Thanks a lot!
Bye
Pali
HF.sm (72.86 KiB) downloaded 1313 time(s).
Thanks a lot!
Bye
Pali
#2 Posted: 12/15/2022 2:31:15 PM
WroteI have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem ?
In some way doctored in red. Setup the integrator scalar wrt 'x'.
Cheers ... Jean.
HF.sm (84.02 KiB) downloaded 1333 time(s).
#3 Posted: 12/15/2022 3:01:55 PM
Hi Pali. At this time, you can't use if(..) inside an integral, use cases(...) instead. Also, SMath's integral new version can handle better units.
HF.sm (73.15 KiB) downloaded 1325 time(s).
#4 Posted: 12/16/2022 6:41:10 AM
Hi Alvaro,
thanks a lot! It works fine. Thank you.
What do you mean: new version of integral?
Pali
Pali
#5 Posted: 12/16/2022 6:42:49 AM
Cheers ... Jean.
I do not really understand what you did, but thanks for your help as well.
#6 Posted: 12/16/2022 9:37:18 AM
1. recast if/else ► if/otherwise.
2. made ∫ scalar wrt 'x' for local/vectorize
HFshort.sm (23.97 KiB) downloaded 1282 time(s).
#7 Posted: 12/16/2022 2:49:11 PM
Hi Pali. In the "new" version of the integral it puts the units of the result correctly, while before some corrections had to be made. From "list of changes" here: Defined Integral supports units now.
Davide Carpi 12/16/2022 6:26:00 PM
1 Pages (7 items)
