1 страниц (7 вхождений)
Problem with integral (again) - Definite Integral - Сообщения
Hi!
I have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem?
Thanks a lot!
Bye
Pali
HF.sm (72,86 КиБ) скачан 1313 раз(а).
Thanks a lot!
Bye
Pali
WroteI have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem ?
In some way doctored in red. Setup the integrator scalar wrt 'x'.
Cheers ... Jean.
HF.sm (84,02 КиБ) скачан 1333 раз(а).
Hi Pali. At this time, you can't use if(..) inside an integral, use cases(...) instead. Also, SMath's integral new version can handle better units.
HF.sm (73,15 КиБ) скачан 1325 раз(а).
Hi Alvaro,
thanks a lot! It works fine. Thank you.
What do you mean: new version of integral?
Pali
Pali
Cheers ... Jean.
I do not really understand what you did, but thanks for your help as well.
1. recast if/else ► if/otherwise.
2. made ∫ scalar wrt 'x' for local/vectorize
HFshort.sm (23,97 КиБ) скачан 1282 раз(а).
Hi Pali. In the "new" version of the integral it puts the units of the result correctly, while before some corrections had to be made. From "list of changes" here: Defined Integral supports units now.
Davide Carpi 16.12.2022 18:26:00
