1 Pages (6 items)
Precision on NonLinear Solvers - How enhance precision of solution? - Messages
#1 Posted: 10/9/2021 2:51:57 PM
Hi, I want to know what is the method of enhance precision in numerical solution into plugin Nonlinear Solvers.
Precision.sm (12.95 KiB) downloaded 1266 time(s).
#2 Posted: 10/9/2021 3:14:52 PM
WroteI want to know what is the method of enhance precision in numerical solution into plugin Nonlinear Solvers.
There is method unless some reference from source.
Some solvers work more accurately then others.
Generally, they will range from 4 decimals to 15 decimals.
Some functions are so involved in numerical error propagation
that you will have to refine the search range ... Goat radius.
Cheers ... Jean.
Precision.sm (20.77 KiB) downloaded 1283 time(s).
#3 Posted: 10/9/2021 3:34:37 PM
Yes, using a initial values more accurately I have a better precision. Thanks so much
#4 Posted: 10/9/2021 8:04:59 PM
WroteYes, using a initial values more accurately I have a better precision. Thanks so much
Another example, much different solver.
15 decimals in Engineering works makes no sense
Cheers for your profitable application(s) ... Jean.
Precision Solve.sm (47.69 KiB) downloaded 1229 time(s).
#5 Posted: 10/10/2021 9:20:41 AM
... both high accuracy solvers in same document.
Your stuff collapsed/disabled.
Occasionally, roots(2), roots(3) are profitable.
Precision Solve.sm (68.45 KiB) downloaded 1250 time(s).
sergio 10/10/2021 12:52:00 PM
1 Pages (6 items)
