Insert unit Angle
Insert unit Angle - Сообщения
#1 Опубликовано: 12.11.2017 12:50:22
Magne Kristian Oen
Magne Kristian Oen
I am new user of Smath and in order to teach myself a bit about this software I am trying make a simple calculation in degrees. However, I cannot find degrees? I cannot find Angle in the insert meny at all? What am I doing wrong?
Best Regards, Magne
#2 Опубликовано: 12.11.2017 13:18:16
you can use
Insert -> Unit -> select "degree"
or shortcut ' -> select "°"
#3 Опубликовано: 12.11.2017 13:21:08
Magne Kristian Oen
Magne Kristian Oen
Sorry my question was inaccurate, degrees as 360 per whole circle not radians.
Thanks for the quick reply anyway!
Magne
#4 Опубликовано: 12.11.2017 13:27:19
Magne Kristian Oen
Magne Kristian Oen
Sorry my bad!
I misunderstood the callout, it IS ordinary degrees!
Thanks and regards, Magne
#5 Опубликовано: 12.11.2017 15:03:03
2/3=38.1972°
#6 Опубликовано: 12.11.2017 22:12:08
#7 Опубликовано: 13.11.2017 04:09:22
Magne Kristian Oen
Magne Kristian Oen
Thank you!
This is exactly what I am unable to do! How do I make the trigonometric function return degrees?
Do I simply type the unit after the result? ( I am sorry if these questions are really daft!?)
Magne
#8 Опубликовано: 13.11.2017 06:50:48
All numerical functions are approximations in computing machinery.
Trigonometric function are in radian. If you want result in °
1. click on the empty place holder of the result,
2. click on the unit drop down menu from the tool bar,
3. click on ° or deg ... scroll down for 'rad' if you want result in radian.
SeaSpray 09.10.2018 17:25:00
#9 Опубликовано: 13.11.2017 07:35:20
Magne Kristian Oen
Magne Kristian Oen
Thank you very much! Now I can make it work. I thought I had tried this but I probably used the input "position" wrong, I believe I simply typed it at the wrong place.
Thank you again, this is great forum!
Regards, Magne
