Wrong result when using function SUM()
Wrong result when using function SUM() - SUM() bug - Сообщения
#1 Опубликовано: 12.06.2015 11:58:36
shelley
shelley
0 сообщений из 15 понравились пользователям.
Could anyone look at this problem? The summation could not recognize the negative sign.
Please see the attached. Marked with yellow is not right.
#2 Опубликовано: 12.06.2015 17:10:52
This is again one of the weird SMath behavior regarding optimization.
Just right click on at least a:=-h region and turn on Numeric optimization
Davide Carpi 12.06.2015 18:04:00, ioan92 13.06.2015 06:49:00
#3 Опубликовано: 18.06.2015 16:35:11
shelley
shelley
Thank you. It works turning on numeric
