1 страниц (8 вхождений)
Most compact units for Vector and Matrix - Easier to read with engineer units - Сообщения
I read some post about units, but my problem occurs only for Vector / matrix.
If a declare a Matrix : P28V with three values (16V, 28V and 31.5V) and I want to display the result, the unit will be for each result : kg*m²/(A*s^3)
Are there some restriction about it?
For each Matrix that I used, I have to specify each time the unit (like V, mA) instead of the bigger one
Another feature, I read a topic about it but without enough explanation. It could be very practical to have automatically the appropriate units factor (M,k, , m, µ, n) before the units.
Thank You, Emilien
Thank You, Emilien
You can use the "unit placeholder" for display in the desired unit. Also can display several units for the same vector.
Yes. Or at least an ENG notation mode, like in the calculators, with scientific notation but with exponents multiples of three.
THank you for your help.
I understant I can change the unit manually to have the desired one.
But it not optimized especially for the vector, each time I have to changed the unit manually. If all the data on the vector have differents units, it take some times.
Have a nice day, Emilien
Off topic, Engineer style ... many solvers don't take units.
Cheers Emilien ... Jean
Inst_Colebrook Pipe Data.sm (71,45 КиБ) скачан 1569 раз(а).
WroteFindRoot() can solve with units.
maple solve and maxima solve can solve units too if I remember correct.
You are just short of many more solvers.
That reminder was from Martin.
