Implicit Plot
Implicit Plot - Сообщения
#1 Опубликовано: 19.02.2018 00:34:45
Hi. I'm trying to implement this implicit plot. But can't "cut" the lines in the xy plot. Also, any help about speeding the function is welcome.
iplotq.sm (40,7 КиБ) скачан 1581 раз(а).
#2 Опубликовано: 19.02.2018 04:35:55
Fridel Selitsky
Fridel Selitsky
Try the method of Draghilev
DragilevMet.sm (24,09 КиБ) скачан 1097 раз(а).
#3 Опубликовано: 19.02.2018 06:07:23
Hi Ber. Thanks for the implementation. But it use maple and is semisymbolic, I want just some that can works in the cloud, like: https://en.smath.info/cloud/sheet/s23Pa6bZUn
#4 Опубликовано: 19.02.2018 06:38:09
Fridel Selitsky
Fridel Selitsky
Option without Maple
DragilevMet1.sm (21,62 КиБ) скачан 1111 раз(а).
frapuano 19.02.2018 07:15:00
#5 Опубликовано: 19.02.2018 07:13:37
Perfect! Thanks.
#6 Опубликовано: 19.02.2018 19:22:41
CBG
CBG
Not graphic
It does not show any error
#7 Опубликовано: 19.02.2018 21:28:12
Hi Carlos
For see the error message type B1=
#8 Опубликовано: 19.02.2018 23:44:57
CBG
CBG
Hello Alvaro:
Thank you very much.
The error in the graph is that x is not defined.
What causes this error?
In the graphs published by you it is seen that graphs correctly.
#9 Опубликовано: 22.02.2018 03:11:16
Hola Carlos. Try the following, a short version, just for n=2.
DragilevMet2.sm (12,74 КиБ) скачан 1097 раз(а).
Fridel Selitsky 22.02.2018 04:44:00
#10 Опубликовано: 22.02.2018 04:21:24
Fridel Selitsky
Fridel Selitsky
Try also the old version of the Draghilev method
DragilevMet3.sm (23,18 КиБ) скачан 1069 раз(а).
Razonar,thanks for the short code for n = 2
#11 Опубликовано: 22.02.2018 14:45:42
Carlos, Alvaro,
From previous use of Dragilev method, I observed great difficulties
to appropriately start/stop rkfixed. Your example above works fine as is.
For more points with less tentatives in specific cases, the easiest way
is to pass it to the closed shape Hermite suite.
I should revisit some of those examples.
The Esplina AI2000 interpolates as well for closed shapes.
Spline Esplina [AI2000].sm (21,79 КиБ) скачан 872 раз(а).
Spline Esplina [Hermite].sm (35,44 КиБ) скачан 877 раз(а).
Fridel Selitsky 22.02.2018 15:50:00
#12 Опубликовано: 22.02.2018 15:55:44
CBG
CBG
By--> Razonar
By--> Ber7
Цитата
Try also the old version of the Dragilev method
DragilevMet3.sm (24kb) downloaded 10 time(s)
Hola Alvaro, Hello Ber7,
Thanks for your reply, but the DragilevMet2 and 3 files do not work.
The file of Ber 7 does not show any error, but by requiring the value
of B1 and B2, it says that "x" is not defined.
Attached drawing of the errors.
Hello Jean, your files worked perfectly.
#13 Опубликовано: 23.02.2018 03:19:44
Hola Carlos.
It's because a problem with rkfixed routine in your environment. Try to download this, or use it in the cloud: DM_RK
#14 Опубликовано: 23.02.2018 15:56:57
CBG
CBG
Hola Alvaro:
Gracias por tu respuesta.
Thanks for your answer, but I found the fault.
The interference is caused by the Maxima Plugin,
by disabling it, the file works correctly.
#15 Опубликовано: 23.02.2018 23:30:39
CBG
CBG
Hola Alvaro
Here too, the problem is caused by the decimal separator "Point",
Changing in options, the decimal separator from "Point" to "Comma", (from "." To ",")
resolves the problem of graphing
Alvaro 24.02.2018 18:48:00
