Slow opening due to Background Image
Slow opening due to Background Image - Files are opening very slowly when there is a background image - Сообщения
#1 Опубликовано: 30.10.2018 13:04:03
alulec
alulec
I am using the SMath for a while, and I really like it. First of all, I would like to thank you for all your efforts.
After I started to using latest version (0.99 - 6839), my files with background images are opening very slowly. Also after the file is opened, any action that I make takes longer than usual. I used the same background image with the older versions but I didn't have the same problem.
I am attaching the same file with and without the background image. In my computer, it takes to 10.673 sec to open the file with the background image, and it takes less than a second when there is no background image.
#2 Опубликовано: 30.10.2018 13:24:16
I opened your files with the latest beta of Smath. The slowdown is much more modest than what you have indicated. I note the size of the two files that the background image is very heavy (about 2 Mb ) and from what I see does not seem justified for the background you get: I think you can do a reduction operation (externally to smath) and optimize the file
#3 Опубликовано: 30.10.2018 13:47:42
Группа: Super Administrator
Hello.
Workaround suggested by Sergio works for me.
In addition I would suggest to use the latest features implemented in SMath Studio: Header/Footer and Full page background together with correct margins. Here is what I get as a result:
BackgroundTest_mod.sm (397,26 КиБ) скачан 1442 раз(а).
Regarding performance - I will fix it soon.
sergio 30.10.2018 14:05:00, frapuano 30.10.2018 14:16:00
#4 Опубликовано: 30.10.2018 14:15:13
alulec
alulec
Thanks for your replies. I will try Andrey's file.
But just for future reference, I downloaded an older version (0.99 6671) and tested another file which is larger (11 pages, same background image, similar amount of calculation per page) it is opened less than a second. Please don't get me wrong, besides the things that I did not do in an optimal way, I just wanted to let you now there is an interesting performance issue. Thank you very much again for your quick replies.
#5 Опубликовано: 30.10.2018 18:17:02
... files with background images ...
I guess I don't understand what is a "background image" in your demo.
2 MB for those 3 gadgets ... Oh !
#6 Опубликовано: 31.10.2018 03:30:23
Jean, this is just an example. User may want to use image with even more resolution because of different reasons (i.e. requirements in the company). The main question is that SMath Studio should be prepared for such situations.
So, it is something to be done in any case.
frapuano 31.10.2018 05:51:00
#7 Опубликовано: 06.11.2018 17:05:00
Performance issue fixed in the latest stable version.
Davide Carpi 06.11.2018 17:08:00, sergio 06.11.2018 17:58:00
#8 Опубликовано: 06.11.2018 18:49:12
alulec
alulec
Thanks a lot Andrey. It works great
