0.99.7067 Beta: unhandled exception
0.99.7067 Beta: unhandled exception - Сообщения
#1 Опубликовано: 11.05.2019 02:18:16
NDTM Amarasekera
NDTM Amarasekera
Attached sm file which appeared recently in the forum works in 7030 (stable), but throws errors in 7067 (Beta).
Some times it crashes when trying to evaluate some variables.
ISERROR QUESTION MARK_B (1).sm (18,72 КиБ) скачан 1468 раз(а).
#2 Опубликовано: 11.05.2019 03:32:48
Confirmed,
Sometimes crashed (red cross over the screen) and sometimes didn't.
#3 Опубликовано: 11.05.2019 04:24:41
Hi. I don't see a bug here, but some kind of issue handling n. About the WYSIWYG notation, it's well know this kind of difficulties not only in SMath, but in mathcad, maple and mathematica too. About the issue with n it must to be solved using Clear, because n isn't local in the sum.
ISERROR QUESTION MARK_Clean.sm (10,4 КиБ) скачан 1475 раз(а).
sergio 11.05.2019 04:33:00, NDTM Amarasekera 11.05.2019 11:25:00, frapuano 11.05.2019 05:32:00, Radovan Omorjan 11.05.2019 04:51:00
#4 Опубликовано: 11.05.2019 05:04:17
Thank you Alvaro, you are right
This problem with summation will come up here and there. It would be enough to put the summation terms inside a single line environment. This behaviour is present in SMath for quite a while. This is easy to forget, but it should not have crashed in those cases. The problem is how to remember this issue and overcome situations like this one.
#5 Опубликовано: 11.05.2019 12:01:03
Can't be more right ! Now you understand why I never updated.
How do you know if it is simply a beta version bug ?
Try this Fourier-algo style.
Fourier Integral Algo Style.sm (7,66 КиБ) скачан 1410 раз(а).
NDTM Amarasekera 11.05.2019 13:15:00
#6 Опубликовано: 11.05.2019 12:30:37
Leave default integral acc 100, only 'N'
Rejects SQRT(x) but takes SQRT|(x)|
Try more ... let us know about your version ... Jean
#7 Опубликовано: 11.05.2019 12:55:36
Generally, the range Σ free style works at time of creation but fails back on new session.
But if included in line program, works for ever. My fft(,) ifft(,) work since day 1 [2015].
The free style Σ is not recognized by Smath kernel.
I have more than fft(,) ifft(,) like Simplex lot more involved works great within line.
I wish to read "Thanks Jean, doctored".
frapuano 12.05.2019 03:58:00
#8 Опубликовано: 12.05.2019 01:08:05
NDTM Amarasekera
NDTM Amarasekera
Thank you Jean.
#9 Опубликовано: 12.05.2019 04:31:34
NDTM Amarasekera
NDTM Amarasekera
The attached sm file also crashes some times when inputs to Polyroots, solve, maple(solve)
are changed or adjusted.
Roots_Ex1.sm (16,06 КиБ) скачан 1389 раз(а).
#10 Опубликовано: 12.05.2019 04:44:58
Tried but it did not crash.
#11 Опубликовано: 12.05.2019 06:30:00
NDTM Amarasekera
NDTM Amarasekera
I had 2 or 3 crashes while testing. It was very strange.
I will try more variations and post if there is any crash.
Thank you you Radovan.
#12 Опубликовано: 12.05.2019 10:37:18
That shouldn't happen, but maybe on latest beta.
1. Polynomials have unique Lagrange format [lot many books are wrong].
2. maple(op(F(u))) will save you manual steps and possible typo errors.
Maths eigenAll Companion.sm (62,14 КиБ) скачан 1378 раз(а).
#13 Опубликовано: 12.05.2019 14:05:10
Please remember to copy and attach here the stack traces when you encounter such critical errors, especially if they are not easily reproducible like this.
#14 Опубликовано: 13.05.2019 01:01:52
NDTM Amarasekera
NDTM Amarasekera
Even after a Clean Re-installation, crashes continued to occur on and off.
Attached sm file crashed when I was doing some changes to either default units,
or copying etc. (I'm not sure). Note where I clicked.
Radial Gate Ex 1.sm (194,77 КиБ) скачан 1349 раз(а).
#15 Опубликовано: 13.05.2019 06:00:09
NDTM Amarasekera
NDTM Amarasekera
Second crash. BTW how do I create stack traces and copy?
Radial Gate Ex 1.sm (195,59 КиБ) скачан 1399 раз(а).
#16 Опубликовано: 13.05.2019 06:54:36
Still not able to reproduce but at least we have an hint.
Simply copy the text from the error window
You can paste in the following BBcodes if it is too long
[spoiler]my text goes here[/spoiler]
or
[code=markup]my text goes here[/code]
#17 Опубликовано: 13.05.2019 08:13:42
NDTM Amarasekera
NDTM Amarasekera
Thanks Davide.
Third crash occurred, and the stack traces (in MS Word) attached.
Radial Gate Ex 1.sm (195,59 КиБ) скачан 1340 раз(а).
7067 3rd Crash-Stack Traces.docx (18,08 КиБ) скачан 852 раз(а).
#18 Опубликовано: 13.05.2019 10:59:12
In 4 years Smath I have observed ONE crash from a corrupted region.
Same in 15 years Mathcad , but several times MCD. Corrupted region
has no explanation. The only cure found was to re-code piece wise
on blank sheet. You could try to isolate the components ...
B1:=B1, C1:=C1 ...etc. even transit via spool to file.
That it crashes by clicking on result once displayed has no other
explanation than critical error, from unknown cause.
Sorry Collab: can't help more, it looks a bug wrt latest beta.
Curiously no more Collab reported such a bug.
