Degree farenheit
Degree farenheit - Сообщения
#1 Опубликовано: 01.02.2015 03:54:45
moy370
moy370
So I am having issues with the temperature units I need to multiply a specific heat value [BTU/lbm*F] by a constant that modifies to the actual Cp value. I keep getting a error? I think it has to do with the units im inputting what can i do to fix this? also I would like to know if its possible to have the output of my units to be automatically changed between English to SI or SI to English as well?
#2 Опубликовано: 02.02.2015 08:37:24
Be careful with temperature units. You have the temperature units and the temperature difference units.
Units temperature
#3 Опубликовано: 02.02.2015 16:21:06
moy370
moy370
Thank you Radovan,
That helped a lot I had no idea smath supported a
temperature difference.
