Draghilev's method
Draghilev's method - Solving systems of nonlinear equations. - Сообщения
#41 Опубликовано: 23.10.2018 06:48:11
Hi Viacheslav. Your examples and procedure, but without plugins (except your XYPlot plugin)
Draghilev's method. Finding roots.sm (743,37 КиБ) скачан 1342 раз(а).
Fridel Selitsky 23.10.2018 07:11:00, Вячеслав Мезенцев 23.10.2018 12:42:00, frapuano 26.11.2018 06:35:00
#42 Опубликовано: 27.10.2019 22:41:44
As far as I can see there are no questions. As I said, everything is quite simple - we follow along the curve of n 1 space. Next, I will tell how to choose a start point, direction, and about the restrictions that follow from the method. I hope that the examples will be added.
From that 7 years old ... that works fine as downloaded,
but turns red as saved SS 6179, not doctored.
As offered in the attached, finding the max is acceptable.
The method suggested for the minima has not been tested.
As it looks: it fails ?
Mathhs NelderMead Himmelblau.sm (160,02 КиБ) скачан 1240 раз(а).
Maths Draghilev's method. Finding extremes. Himmelblau function version 0.2.sm (370,71 КиБ) скачан 1313 раз(а).
#43 Опубликовано: 27.10.2019 22:50:02
... that one.
Maths NelderMead Himmelblau.sm (160,02 КиБ) скачан 1290 раз(а).
