Draghilev's method - Solving systems of nonlinear equations. - Сообщения
Hi Viacheslav. Your examples and procedure, but without plugins (except your XYPlot plugin)
Draghilev's method. Finding roots.sm (743,37 КиБ) скачан 1378 раз(а).
Fridel Selitsky 23.10.2018 07:11:00, Вячеслав Мезенцев 23.10.2018 12:42:00, frapuano 26.11.2018 06:35:00
WroteAs far as I can see there are no questions. As I said, everything is quite simple - we follow along the curve of n 1 space. Next, I will tell how to choose a start point, direction, and about the restrictions that follow from the method. I hope that the examples will be added.
From that 7 years old ... that works fine as downloaded,
but turns red as saved SS 6179, not doctored.
As offered in the attached, finding the max is acceptable.
The method suggested for the minima has not been tested.
As it looks: it fails ?
Mathhs NelderMead Himmelblau.sm (160,02 КиБ) скачан 1292 раз(а).
Maths Draghilev's method. Finding extremes. Himmelblau function version 0.2.sm (370,71 КиБ) скачан 1366 раз(а).
