RF Resistance Calculation - Using ber, bei functions - Сообщения
My first post. I'm trying SMath instead of MathCad P4.Файл не найден.Файл не найден.
Having difficulties transferring the RF resistance sheet from MC15. The ber, bei functions are missing. I added plugin EFI for Mathcad for the "Jv" (vs. Jn) function but it doesn't appear in the listing of available functions.
Attached is the mc file and my attempt to transfer to SMath.
I welcome the collabs help to move forward.
Sincerely,
nasch
Sincerely,
nasch
WroteThe ber, bei functions are missing
Check if you can do something from the Smath built-in
mwbessl [i,j,k,y] from the f(x) menu.
Thanks, for your reply. Unfortunately, I do not see "mwbessl..." listed. Maybe something that I need to activate? Is there a certain plugin I need to load?
Thanks, again
Thanks, again
WroteI do not see "mwbessl..." listed
You may have to install from the plugin list.
Click on "Tools", click "Plugins" ... install all.
Otherwise, rescue to "Smath Doctors" ... [Martin, Davide ...]
Bessel Midwest.sm (8,83 КиБ) скачан 1117 раз(а).
Sorry Collab, can't help + ... hope Smath Doctors catch your pain.
Try with my portable distribution, see signature. There, the mathlib.dll (mathcad special functions) is installed and the bitness of the executable is adjusted.
The screenshot below is from the interactive handbook. You find it using the [?] button in the toolbar in the distribution mentioned above.
Goto Plugins> EFI for SMath Studio> Special functions.
![2017-11-30 19_23_19-SMath Studio 0.98.6484 - [Section Special functions.sm].png](/ru-RU/files/Download/FurKGy/2017-11-30-19_23_19-SMath-Studio-0.98.6484---[Section-Special-functions.sm].png)
Try this.
Links:
1. Cephes Mathematical Library.
mathlib.dll must be uninstalled (removed manually) from the Mathcad EFI plugin. Cephes Mathematical Library contains same functions.
Links:
ЦитатаThere, the mathlib.dll (mathcad special functions) is installed and the bitness of the executable is adjusted.
WroteThen again, I do not have admin rights (my work PC), so that may be a problem?
No, you have to set 32-bit version flag for the SMath Studio Desktop exe file.
Links:
1. Matlab C++ Math Library 2.1 (Win32)
Many thanks! "Jv" is now defined. But "arctg" is not. Another plugin?
WroteMany thanks! "Jv" is now defined. But "arctg" is not. Another plugin?
Name of trigonometric functions depend on the function naming type in global settings of your smath studio; in your case you should look for atan
Thank you! Now it computes, but the value; Rac(100kHz) is negative. Should be 141.553Ohm/Mi. I need the "angle" function definition from Mathcad. angle(x, y) Returns the angle from the x-axis to a line containing the origin and the point (x,y). Results are in radians between 0 and 2π, excluding 2π.
Wroteangle(x, y)
NFG ... arg(1+1*i)=45°
WroteUsing an old MC definition I obtained a better value:
These two documents may be of interest next blue moon.
Mostly if you need accurate Γ(x) ... Smath built-in ± 4/5 D
Bessel JY.sm (64,79 КиБ) скачан 1152 раз(а).
Maths Special Gamma(x) 15D.sm (75,81 КиБ) скачан 1168 раз(а).
Many thanks!
Thanks again for the collab's help. The work sheet displays the same result as MC. AC-DC Resistance Using Bessel Functions.sm (12,68 КиБ) скачан 1218 раз(а).
Now I have a fault using a modified sheet that the "Result is above max. allowed positive number."
. The limit for Rac(f) is 9.3MHz, then the error shows.
The result should be 219 micro-ohm/cm. Why the limit?
nas
Bellow Equiv Resistance.sm (14,43 КиБ) скачан 1194 раз(а).
nas
WroteThe result should be 219 micro-ohm/cm. Why the limit?
Here, it says ... Jv(,,) not defined.
Something triggered in the factorization of the ratio be(...)/be'(...) you can make it working with a trick
![2017-12-07 12_39_30-SMath Studio - [Bellow%20Equiv%20Resistance.sm_].png](/ru-RU/files/Download/RN6LCb/2017-12-07-12_39_30-SMath-Studio---[Bellow%20Equiv%20Resistance.sm_].png)
