Snippet Operations with units Fail
Snippet Operations with units Fail - Fails on some occasions to detect the units - Сообщения
#1 Опубликовано: 16.05.2022 19:05:41
CBG
CBG
Hello
The unit operation snippet fails to detect units.
Snippet_Units_Fail.sm (33,04 КиБ) скачан 1680 раз(а).
#2 Опубликовано: 17.05.2022 09:02:34
Try this
Snippet_Units_Fail.sm (32,38 КиБ) скачан 1601 раз(а).
#3 Опубликовано: 17.05.2022 09:12:04
Hola Carlos ... Jean...OK SS 6179
#4 Опубликовано: 17.05.2022 16:51:34
CBG
CBG
Hello David
Цитата
Try this
Thank you very much for your answer, but the snippet fails, since instead
of finding the units, it only obtains the value of 1
Hola Jean
Saludos
#5 Опубликовано: 18.05.2022 04:44:35
Hello David
My bad, IDK why but yesterday seemed to work to me, but in fact it doesn't. I'll give another look at the snippet ASAP.
#6 Опубликовано: 18.05.2022 14:00:44
I see the issue. The function look for a numerator/denominator pattern in the num2str() text, but doesn't handle cases in which multiple divisions are involved.
#7 Опубликовано: 18.05.2022 22:47:59
CBG
CBG
Hello David
Thank you very much for your attention, I hope the Snippet has a fix-
On the other hand, I ran the snippet in version 6179,
and it works perfectly. How is that possible?
#8 Опубликовано: 19.05.2022 08:28:50
I'm not sure, however if you need a urgent fix here you have an easy way to make it working the same way.
