1 страниц (10 вхождений)
Interpolation TREASURY [20210525] - Interpolation TREASURY [20210525] - Сообщения
This Legacy goes back 20 years ago.
In applied mathematics, interpolation is the most difficult task.
The Smath Akima is a piece of gold, well exemplified.
In the mean time of eventual refresh ... enjoy/benefit.
Take care ... Jean.
Spline Interpolation TREASURY-InspectDATA Copy.sm (25,13 КиБ) скачан 1265 раз(а).
Spline Interpolation TREASURY-MATRIX Copy.sm (82,32 КиБ) скачан 1291 раз(а).
Spline Interpolation TREASURY-ainterp(x) Copy.sm (117,03 КиБ) скачан 1266 раз(а).
Spline Interpolation TREASURY Copy.sm (1,65 МиБ) скачан 1255 раз(а).
Take care ... Jean.
WroteIs it possible to use this method to approximate a function like the one in the picture?
If you have it working in Smath, please attach the document.
The Thiele model you have red in my attachment can be reduced in J_Fraction
via Maple and manual suite. I have very many of those J_Fraction.
Mathcad 8, 11 converts directly Thiele and rational fraction to
J_Fraction, but not Smath/Maple.
Thanks for your appreciation ... Jean
I have attempted to construct your picture.
It produces a graph. I see no way to reduce further whereas
it is not simply numerical. If you leave it this way, then
it will track the parameters [R0, Lo, k, a] which are
presumed resulting from previous calculations.
Does it help ? ... Jean
Unknown CF.sm (26,58 КиБ) скачан 1228 раз(а).
... at this point, your continued fraction if numerical
can be reduced to J_Fraction of substantial visibility.
You will have to carry the manual procedure for each
numerical valued system ... observe the β construction
Please give news ... Jean
Thiele UNKNOWN parametric [4].sm (50,45 КиБ) скачан 1049 раз(а).
Wow!!!!! Thanks for you ultra very quickly answer
I thought about using Thieles interpolation too. but I don't understand how adapt this function for my needs, because I am very far in this area of knowledge.
THIELE_INTERPOLATION_ AND_REGRESSION_SS7251.sm (210,63 КиБ) скачан 1303 раз(а).
This's example from CBG(It's user this forum) and I wanted used it.
Thank you Jean
Thank you Jean
WroteI thought about using Thieles interpolation too. but I don't understand how adapt this function for my needs, because I am very far in this area of knowledge.
Beautiful Annunciation Cathedral ... I love Russian Coupoles.
I can make zillions of this shapes in Smath.
Continued fractions originate from Mesopotamia 1000's years BC.
Probably from Aliens visit card.
They appeared in modern computing machinery in the earlier IBM Main Frame.
Explained in details in C.T. Fikes.
Since then, functions resident in Windows are normalized rational fractions.
Normalized is Num(x)/[1+Denom(x)... in Bible Hart et Al.
In fact, the sole interpolation method that relates directly X, Y
is the continued fraction as applied Thiele from true/clean data.
All other methods rescue themselves from accessory maths.
If you have more applications, please don't hesitate.
Commonly, Cholesky passes monomials through all or some points.
The pieces need not be monomials, as per the attached *.sm.
INTERPOLATION was not intended to fit model functions.
Fitting model function(s) to data is a much longer story.
An immense Compendium of fitted data in my Smath.
Take my friend ... Jean.
Genfit [Algo Minimize(Cholesky)].sm (27,79 КиБ) скачан 1030 раз(а).
Thiele UNKNOWN parametric [4].sm (45,77 КиБ) скачан 1035 раз(а).
Inst_Water viscosity [cP].sm (55,31 КиБ) скачан 1043 раз(а).
Inst_Type Pt100 XFR Thiele.sm (50,06 КиБ) скачан 1185 раз(а).
Inst_Type T_J NBS Resume.sm (152 КиБ) скачан 1190 раз(а).
This Thiele MERITAS ... as applied.
Thiele McCabe Companion MERITAS Copy.sm (76,95 КиБ) скачан 1223 раз(а).
Thanks Jean. How many interesting materials have you provided. Study now more than one evening. Yes, our cathedral is not bad at all. What tourist attractions do you have in Canada?
Oh!!! Your country have many interesting and beautiful places.
WroteWhat tourist attractions do you have in Canada ?
1. The Canadians themselves and spending a year with our Native Ancestors.
2. Niagara Falls are impressive !
3. Trecking the Rockies, wait wild goats have finished snoozing on the road.
4. Plenty of National/Provincial Parks.
Have a good day ... Jean.
