Showing a values of symbolic
Showing a values of symbolic - Сообщения
#1 Опубликовано: 19.01.2026 17:30:29
Adrian
Adrian
Is there any option to make smath show a numbers he calcualte, before a result?
For example if i write a=2 b=3 and then write a+b i will get a+b=5. I want smath to show a+b=2+3=5. is that possible? There is any addon for that?
Thank you for any help!
#2 Опубликовано: 20.01.2026 11:12:46
Hi, this is not possible in SMath, or only with heavy workarounds.
I think you want something like this (as in Blockpad)
Also LibreOffice with the iMath-extension can produce such displays, yet you have to input some formatting codes in the formula editor.
#3 Опубликовано: 23.01.2026 10:34:03
Adrian
Adrian
how i can show that reference values?
ok, i found it! Thanks for help!
Отредактировано 23.01.2026 10:42:41
