format results polar in degrees
format results polar in degrees - How to show matrix results in polar format in degrees - Сообщения
#1 Опубликовано: 12.10.2025 18:46:36
Russ Patterson
Russ Patterson
I am one tiny step away from freeing myself of Mathcad Prime. I just need to know how to format the result of a matrix/vector operation so it is in polar form with angle in degrees. The attached image is a snip from a Mathcad result. How is this possible in SMath?
best regards,
russ
#2 Опубликовано: 13.10.2025 06:58:46
fominantokha
fominantokha
See
https://smath.com/en-US/forum/topic/kAz5NZ/How-to-do-polar-form-like-mathcad_
Отредактировано 13.10.2025 06:59:51
#3 Опубликовано: 13.10.2025 13:40:26
Russ Patterson
Russ Patterson
Thank you. That does not address formatting a vector result in polar with degrees (what I'm after) as best I can tell. I want to display my resulting vector in polar with degrees.
Also, I tested the "pol" function and it assumes the angle is in radians.
Worksheet1.sm (10,64 КиБ) скачан 1001 раз(а).
#4 Опубликовано: 14.10.2025 09:09:21
1 125 сообщений из 1 798 понравились пользователям.
Hi. You can try something like this, using the table plugin.
showPolarForm.sm (18,3 КиБ) скачан 1035 раз(а).
Russ Patterson 14.10.2025 18:01:09
#5 Опубликовано: 14.10.2025 18:04:28
Russ Patterson
Russ Patterson
Thank you. That works rather well.
1) Is there a way to hide that showPF function at top of my worksheet?
2) I can't figure out how to make it report a very tiny imaginary component as zero. See bottom of attached. showPolarForm.sm (20,74 КиБ) скачан 1068 раз(а).
best regards,
russ
p.s. It would also be great if we could control the table borders at an individual column level - so I can make it look like brackets around the results.
#6 Опубликовано: 14.10.2025 18:27:56
1) Menu --> Insert --> Area. Place the functions you want to hide between the two lines. Then click the little square with the – sign to collapse the area."
Russ Patterson 14.10.2025 20:42:47
#7 Опубликовано: 14.10.2025 22:59:16
Hi. Modified version.
showPolarForm.sm (21,93 КиБ) скачан 1091 раз(а).
sergio 15.10.2025 17:42:32, Russ Patterson 15.10.2025 20:51:43
#8 Опубликовано: 15.10.2025 20:51:58
Russ Patterson
Russ Patterson
Outstanding! thank you
