Vector representation of Strings?
Vector representation of Strings? - Сообщения
#1 Опубликовано: 21.09.2025 19:21:48
Stuart Bruff Y
Stuart Bruff Y
Is there a method within SMath for converting between strings and vectors of Unicode Points (or ASCII codes)? That is, a means of accomplishing what Mathcad's str2vec and vec2str do?
#2 Опубликовано: 21.09.2025 21:15:09
You can use Maxima.
string.sm (5,5 КиБ) скачан 1185 раз(а).
Отредактировано 21.09.2025 21:16:32
Stuart Bruff Y 23.09.2025 13:46:30
#3 Опубликовано: 22.09.2025 00:33:10
1 125 сообщений из 1 798 понравились пользователям.
Hi Stuart. Nice to read you. You can use the functions in this post: https://smath.com/en-US/forum/topic/bppdgC/String-utilities, which, while not very efficient, at least get the job done.
#4 Опубликовано: 23.09.2025 13:50:55
Stuart Bruff Y
Stuart Bruff Y
You can use Maxima.
Thanks, Martin.
Stuart
