Maxima Assume doesn't work
Maxima Assume doesn't work - Сообщения
#1 Опубликовано: 04.04.2019 11:11:28
Lorenz Grimm
Lorenz Grimm
I'am not able to use the assume function.
Currently Maxima 5.42.2 is used.
I would appreciate any ideas
Thanks,
Lorenz
#2 Опубликовано: 04.04.2019 12:53:06
There are 17 ODEsolve in Smath that will do.
#3 Опубликовано: 04.04.2019 19:26:12
Thanks,
Lorenz
Can't reproduce.
You might want to use symbolic evaluation for the assume call.
frapuano 05.04.2019 06:46:00
#4 Опубликовано: 05.04.2019 04:09:37
Also, can work with complexes ...
MaxODE.2.sm (17,68 КиБ) скачан 1125 раз(а).
#5 Опубликовано: 05.04.2019 04:15:27
Lorenz Grimm
Lorenz Grimm
Hi Everybody,
thanks a lot.....I forgot to evaluate symbolically the assume command....
