µ & nH
µ & nH - Сообщения
#1 Опубликовано: 28.04.2016 17:58:28
Celestion
Celestion
Can you make Smath recognise the letter "µ" on the keyboard ?
Also, can you add those units directly in SMath:
nH (nano Henries)
mHz (milli Hertz)
µohms
Thank you very much !
Marc
#2 Опубликовано: 28.04.2016 18:52:08
1 440 сообщений из 2 930 понравились пользователям.
type m then press CTRL+G (wiki , Activebook)
#3 Опубликовано: 28.04.2016 21:38:22
Å (Angstrom)... press Alt, while pressing [Alt] type 0197 on the numeric pad.
Type m Cntrl+G to get μ then type o ... μo => permeability of vacuum.
nH:=μH*10e-3 [nanoHenry]
Salut Marc: cheers, Jean
#4 Опубликовано: 28.04.2016 22:41:32
§ [Alt+0167]
å [Alt+0229]
¼ [Alt+0188]
Ø [Alt+0216]
These kind of character [0xxx] start @ 33 up to 255.
Smath recognises only very few of them.
€ [Alt+0128]
☼ [Alt+15]
#5 Опубликовано: 03.05.2016 12:34:46
I use the latest version for mono, and i've installed additional packets like xfonts-base,
xfonts-100dpi, xfonts-75dpi just in case
These are very important informations! (hard to replicate otherwise)
