Matrix of order 0
Matrix of order 0 - Creat matrix of order 0? Please. - Сообщения
#1 Опубликовано: 03.02.2017 15:22:41
josef
josef
I writing work on High School on topic IIR filtres and I need to create matrix of order 0.
In matlab:
p_0_NDP = []
p_0 = Omega_n * p_0_NDP;
In SMath studio?
x:#clean# - does not work
Thank you for help.
#2 Опубликовано: 03.02.2017 16:01:09
ZeroMatrix: like this
#3 Опубликовано: 03.02.2017 16:17:16
josef
josef
But it is not. If I insert M(0) is length matrix 1, but I need length matrix 0
#4 Опубликовано: 03.02.2017 16:40:58
Arie
Arie
I don't believe SMath supports empty Matrices.
#5 Опубликовано: 03.02.2017 16:47:50
Arie
Arie
Can you upload an example of what you're trying to accomplish?
We might be able to help implement it a different way.
#6 Опубликовано: 03.02.2017 18:07:24
josef
josef
You can send e-mail adress on you? I need help about SMath studio functions. Thank you.
#7 Опубликовано: 03.02.2017 18:51:10
But it is not.
A matrix of order zero is a "zero matrix"
If you want it rectangular from the fx menu
'Ones(3,5)' ,,,, then of any value: *1.23456789=
#8 Опубликовано: 03.02.2017 21:29:55
Example for declaration and use of an empty matrix:
stack.sm (11,99 КиБ) скачан 1556 раз(а).
Arie 03.02.2017 22:03:00
#9 Опубликовано: 03.02.2017 22:03:19
Arie
Arie
Awesome. Thanks, Martin. I did not know that empty matrices were supported.
#10 Опубликовано: 04.02.2017 00:07:50
... a more elegant way to "skin the cat".
#11 Опубликовано: 04.02.2017 10:32:43
... technical matrix
#12 Опубликовано: 04.02.2017 14:38:17
At this point, you know how to create a "zeromatrix".
Visit "Samples => PseudoInverse" few days ago,
This type of matrix: you fill-in manually.
The other style matrices construct by themselves from their
governing algorithm. Download the attached work sheet.
I may be wrong but I would think your IIR filter is one of
this type matrix that constructs around the IIR algorithm.
Spline l_p_c.sm (145,3 КиБ) скачан 1534 раз(а).
