[OpenSuse] symbols not showing properly on screen
[OpenSuse] symbols not showing properly on screen - Сообщения
#1 Опубликовано: 30.06.2022 15:49:24
charlamb
charlamb
1 сообщений из 16 понравились пользователям.
I don't know if someone has seen this before but I'm having problems with SMathStudio showing assign/evaluate (:=,=) and math operators (+,-) as shown below:
does anyone have an idea of what is going on?
I'm using OpenSuse, SMathStudio (Windows version with wine, but it also happens with the Mono version as well), latest stable/beta versions. It happens with new worksheets and with loaded worksheets.
#2 Опубликовано: 30.06.2022 19:11:06
601 сообщений из 1 382 понравились пользователям.
What I did was simply copying Courier New fonts from windows disc to my linux.
Here all the Courier New files on my pc.
The path for font files should be copied is /home/{USER}/.local/share/fonts/
This has worked very well. At least how it is for me.
courier.zip (1,61 МиБ) скачан 737 раз(а).
May be a font issue.
Try to download courier new font and copy to proper location mentioned above.
sergio 01.07.2022 12:04:00
#3 Опубликовано: 02.07.2022 12:40:16
charlamb
charlamb
Hi, I tried the courier font as well as other fonts and still it doesn't work.
Also, the program crashes if I try to change the font family:
I placed all font families in the folder mentioned before.
Best regards,
#4 Опубликовано: 02.07.2022 14:16:18
Try to run with mono, not wine.
#5 Опубликовано: 02.07.2022 18:46:11
charlamb
charlamb
Same behavior, with mono:
#6 Опубликовано: 03.07.2022 08:58:31
I still see wine symbol at titlebar of error message.
Please make sure you have installed mono package installed.
And could you please check your inbox?
I will try to continue to help you from there.
#7 Опубликовано: 04.07.2022 16:39:24
I have tried Smath with openSUSE_leap_15.4_live iso.
Seems everything is fine and working as it should be.
At first I tried with appimage I created. It is v0.99.7822 and it worked flawless.
Then I have installed mono-complete and downloaded latest v1.0.8206.
And there was no issue with it either, no problem with symbols or anything else.
Can't help you further from here without additional information.
