Aligning text & variable with exponent
Aligning text & variable with exponent - How to align bottom of text with bottom of an expression with an exponent? - Сообщения
#1 Опубликовано: 15.11.2020 22:27:07
Fran Lee
Fran Lee
1 сообщений из 44 понравились пользователям.
When I use the Align "Horizontally" tool to align a text box with an expression with exponents... it aligns the text to the top of the exponent.
Is there anyway to have it align the text with the bottom of the expression's base?
Thanks.
#2 Опубликовано: 17.11.2020 00:39:47
Hi. SMath align at top. Mathcad align at bottom. It's just a different convention, I guess. Word and Wolfram Mathematica have some options for different alignments, but are not easy to change them.
#3 Опубликовано: 17.11.2020 06:40:45
1 353 сообщений из 2 266 понравились пользователям.
Use a text region with embedded math regions (when in text, Insert> formula). The embedded math regions are active (those in the writer plugin are not) and are executed in the serial line sequence regardless what their vertical extent is. This may be misleading because you can't always easily guess whether a formula is inside a text region or just on the canvas.
This way you can create ambiguous relations between appearance and logic.
sergio 17.11.2020 13:44:00
#4 Опубликовано: 18.11.2020 06:39:59
Fran Lee
Fran Lee
Once in "formula" mode how do you get back to text while in the same region?
#5 Опубликовано: 18.11.2020 10:54:43
Sorry, don't understand. You can convert algo(U) into string, pretty long and useless
unless you want that into script, for what kind of gadget vs Smath CAS.
#6 Опубликовано: 18.11.2020 13:56:59
1 442 сообщений из 2 935 понравились пользователям.
Just press the enter key.
#7 Опубликовано: 18.11.2020 22:57:34
As a side note, handle this kind of maths with caution.
There is no verdict, except possibly Mathematica. Sorry, no time to spare on that.
