1 страниц (5 вхождений)
Stack - Stack - Сообщения
#1 Опубликовано: 31.03.2016 11:02:59
#2 Опубликовано: 31.03.2016 11:09:51
#3 Опубликовано: 31.03.2016 13:25:24
#4 Опубликовано: 31.03.2016 13:40:17
Wrote... I can see some "improvement" ? in your latest Smath.
Pun intended ? Did not get this. Also it is not "my Smath" by any stretch - all is Andrey's hard work.
Anyway I did not get your post - just my slow mind I guess.
#5 Опубликовано: 31.03.2016 21:21:24
Unlike "augment" that is a conclusive operation, "stack" is not a conclusive operation.
Unless "List is vectorised", as defined it is NOT a vector even if it displays as vector.
"List is a scalar vector". So, it won't sum. The module V(List) creates "List" as a vector,
then suited for sum. In the definition u:=1..5 ,,,, u is anything and nothng unless ASSIGNED
active [per say valued]. That's why the error message "Must be a vector" .
"Must be a vector" whether by the vectorising operator or by user creation.
Новые сообщения
Нет новых сообщений
