Trouble finding location of the maximum of f(x) function using derivatives
Trouble finding location of the maximum of f(x) function using derivatives - I am trying to find the location where maximum moment occurs. I have - Сообщения
#1 Опубликовано: 14.08.2025 16:03:29
DM
DM
0 сообщений из 12 понравились пользователям.
Hello all,
I am trying to develop a method to calculate the location of maximum moment using the superposition method. My thought was to create an expression M(x), take the derivative = 0 which would be the location of maximum moment.
However, I'm not sure why the solver isn't returning any roots. Is this a problem because my variables have units?
I read into https://smath.com/en-US/forum/topic/WRWWAT/Max-value-of-function thread and the second post had an example file, but my function was not working in there when I tried replacing it.
As an aside, what is the vertical bar in this photo called and what is it's purpose? I tried searching for it but I have no clue what it is even called. Same goes for the arrow above the f(x_c).
Moment Test.sm (30,71 КиБ) скачан 1365 раз(а).
Отредактировано 14.08.2025 16:08:28
#2 Опубликовано: 15.08.2025 02:26:25
Hi. Yes, you are right, there is a problem with the units. This is a way for handle units using solve:
About the line() instruction in the examples that you mention, as in smath the calculations are performed from left to right and from top to bottom, it is simply used so that the graph on the right can be drawn, otherwise it would have to be placed below.
Your problem solved using the procedures in the reference:
maximun.sm (51,09 КиБ) скачан 1409 раз(а).
Отредактировано 15.08.2025 03:53:03
sergio 15.08.2025 09:36:51, ioan92 15.08.2025 09:39:10
#3 Опубликовано: 15.08.2025 11:54:25
StvMath
StvMath
44 сообщений из 76 понравились и 1 не понравились пользователям.
It works like this:
#4 Опубликовано: 15.08.2025 14:02:35
DM
DM
It works like this:
Hello! For your x solve how come you put h in the brackets when it is a constant? The post above yours doesn't have as many inputs but appears to accomplish the same thing. What are the extras in your solve call doing?
#5 Опубликовано: 15.08.2025 14:03:18
DM
DM
Is there a way to have the solve only spit out the positive number for x instead of a matrix?
#6 Опубликовано: 15.08.2025 15:11:45
StvMath
StvMath
The '0' and the 'h' are the limits of x between which 'solve' searches for a solution.
#7 Опубликовано: 15.08.2025 18:41:53
... Is there a way to have the solve only spit out the positive number for x instead of a matrix?
Hi DM. There are several ways. This two, for example:
Moment Test.sm (33,91 КиБ) скачан 1369 раз(а).
... Hello! For your x solve how come you put h in the brackets when it is a constant? The post above yours doesn't have as many inputs but appears to accomplish the same thing. What are the extras in your solve call doing? ....
Hi Stv. Which solve?
#8 Опубликовано: 15.08.2025 19:40:12
StvMath
StvMath
Hi Alvaro,
Not sure what you're getting at! I simply took the 'solve' that DM had used and added the two limits (0 and h), as well as inserting units.
Best regards,
Stv.
Alvaro 15.08.2025 22:07:35
#9 Опубликовано: 15.08.2025 22:19:04
... Not sure what you're getting at! I simply took the 'solve' that DM had used and added the two limits (0 and h), as well as inserting units. ...
It seems my browser didn't load the image you attached when I ask about which solve. I just saw your image now. You're right; the most practical way is to limit the search to the range [0, h].
