Data Exchange plugin
Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Сообщения
#181 Опубликовано: 23.05.2021 07:44:04
1 442 сообщений из 2 935 понравились пользователям.
PLUGIN UPDATED SMath Studio 0.99.7808 and later
  • fixed encoding/decoding issues;
  • refactoring;
#182 Опубликовано: 05.08.2021 10:04:01
Stefano
Stefano
0 сообщений из 22 понравились пользователям.
when saving as odt with the option to convert to libreoffice math object, negative quantities loose the minus sign only if the haven't any other element in front of them. For example:
Цитата
a:=4-9=-5
it get converted to
Цитата
a:=4-9=5
For context, I just discovered this app so it could be that I am simply ignoring something obvious.
Файл не найден.->Файл не найден.
#183 Опубликовано: 05.08.2021 17:25:52
Seems a bug in the plugin, thank you for reporting it
#184 Опубликовано: 24.12.2021 01:52:45
susilo widyatmoko
susilo widyatmoko
5 сообщений из 9 понравились пользователям.
can I use this plugin (csv export) in viewer/exe file? so user can get output from exe file
#185 Опубликовано: 29.12.2021 20:16:47
Hello [userlink]Susilo Widyatmoko[/userlink],
Yes, you can. If you want to let the user choose a path, there is the path picker region, otherwise you might choose a default output, f.e. if you choose an empty string as third argument ("") the file will be created next to the executable.
#186 Опубликовано: 03.06.2022 08:56:14
RaiHil
RaiHil
Hello Davide,
thank You for Your very useful Plug-in!
I use it regularly to paste my Smath calculations into MS Word.
In order to be able to arrange and organize formulas and text better, I use text regions.
Unfortunately, text regions containing formulas are not saved properly in the *.odt files.
Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files?
Thank You verry much
Raimund
#187 Опубликовано: 06.06.2022 13:51:47
Hello [userlink]RaiHil[/userlink]
I'll look into it, although last time I've checked nested regions weren't easy to manage plugin-side.
#188 Опубликовано: 09.06.2022 11:52:55
RaiHil
RaiHil
Thank you, I appreciate your effort!
