Factor polynomials?
Factor polynomials? - Сообщения
#1 Опубликовано: 09.10.2014 02:41:33
vnaumov
vnaumov
Does SMath support factoring polynomials, like:
2x + 6
=> 2(x + 3)
#2 Опубликовано: 10.10.2014 11:00:44
Gerry_Bush
Gerry_Bush
12 сообщений из 14 понравились пользователям.
Hello vnaumov,
I have tried your example using symbolic evaluation and SMath gives the result:
2.x + 6 = 2.(3 + x)
Is this what you need?
vnaumov 11.10.2014 03:58:00
#3 Опубликовано: 10.10.2014 13:40:49
1 554 сообщений из 1 864 понравились пользователям.
You can use Maple or Maxima for this purpose.
#4 Опубликовано: 11.10.2014 03:52:38
vnaumov
vnaumov
Thank you, Maxima does factoring, like x^2 + 4*x + 4 ==> (x + 2)^2
I downloaded "Unofficial portable distribution with Maxima", https://smath.com/wiki/%28S%28p1gq0245uny440554qdivzik%29%29/SMath%20with%20Plugins.ashx
